  3. Abstract Generator : 2 layouts of a same "Memory instance...
  • Views 1461
Abstract Generator : 2 layouts of a same "Memory instance" identified as "Block" and "Core" why ?
samung
samung over 12 years ago
I would like to understand one point : I have 2 layouts of a memory instance (array of bitcells, master control block, I/O ... which are not flatten), with a global PR Boundary all round the memory instance. Actually, that's two versions of the layout.
Abstract Generator consider one of the layout as a "Block cell" (ok this is expected) and the other as a "Core cell". Does anyone know how it happens ?
 I think, in my scripts I will force the cell to be either a "Block" either a "Core" depending if it is a Memory instance ("Block") or a standard cell ("Core"), in this way I will be sure of the operations which will occur with the layout as input and I will have a proper LEF file definition with "CLASS BLOCK" or "CLASS CORE". This is a weird behaviour ?
Thanking in anticipation.
P.
Tool :
 cadence_amsams2010.2c_mmsim/lnx/doc/abstract
IC6.1.5-64b.500.9
  • ColinSutlieff
    ColinSutlieff over 12 years ago
    I just quickly checked this and it seems that any new view automatically gets put into the "core" bin.
    From an earlier post I suggested you move a cell from "core" to "block" so I believe this is O.K.
    I believe you moved one layout to "block" manually, the other was put into "core" automatically.I don't know any way that the tool would automatically put 2 different layouts into 2 different bins.
    Your last sentence is correct. Normally there are different rules controlling how the abstracts are generated (depending on the cell type).
    That is the reason for the different bin types.
    Colin
