  3. Using the Forum
  • Subscribers 133
  • Views 14346
Using the Forum
archive over 20 years ago
Welcome to the custom IC Layout forum, a place to keep your finger on the pulse of the latest software developments and happenings in the areas you care about most. Get to know the experts, both inside Cadence and in our worldwide Custom IC user community. Ask your questions, get answers, and share best practices. Tell us what's on your mind...other users want to know what you think.
This forum is not intended to be a substitute for Cadence customer support and/or documentation, but we do believe that it will be helpful and a way to tap into vast knowledge that exists in our user community. Of course, any software support, documentation and installation issues should also be directed to your preferred Cadence support channels.
File attachments must use one of the following file extensions:.doc, .pdf, .html .zip, .il,.jpg,and .gif. Size limit on the attachments is 750KB. If you have questions or need help with attachments, send an email to community_moderator@cndusers.org
Administrator, cdnusers.org
Originally posted in cdnusers.org by Moderator
