  3. RVE CN command equivalent to PVS
  • Views 16421
jorenrefuerzo
jorenrefuerzo over 12 years ago
Were currently swithing from using Calibre RVE to PVS.
Do someone of you know the equivalent value of the "CN" in the .db file of RVE into PVS?, by the way the CN means Cell name wich basically used liked this:
CN subcellA        <-- this denotes that the coordinates below are in the subcellA
-370 2310 -370 2290
Joren
    Hi Joren,
    I checked with one of my colleagues who knows PVS in more depth than me:
    PVS can also output CN.
    It depends with following command settings:
      cell_name [ -drc | -erc ] { yes [ -cellspace ] [ -xform ] [ -all ] } | no
    With cell_name -drc yes
      Cell names are output, but coordinates remains in the topcell space.
    With cell_name -drc yes –cellspace
      Cell names are output, coordinates are in the cell space.
    Other possibilities are:
      cell_name -drc yes -xform
      cell_name -drc yes -all
    In the GUI, that option is controlled from the Output Tab:
    • Output Errors Hierarchically - Select one of the following three options from the drop down list:
      • On: This is equivalent to cell_name -drc yes -xform. Error markers will be contained in the subcells. The same setting in the rule deck will be overridden
      • Off: This is equivalent to cell_name -drc no. Coordinates of all subcell error markers will refer to the top cell. The same setting in the rule deck will be overridden.
      • Rules Definition: Rule deck setting will be used. This is the default behaviour.
    So running from GUI, you need to turn that option ON to get the “CN” lines in the ASCII DRC output.
  • jorenrefuerzo
     HI Andrew,
    Thanks for your quick response,
     I was able to have a CN value now in the output .db fle
    using the : cell_name -drc yes -cellspace -xform
    and the output is:
    CN plc_x1quad c 1 0 0 1 27060 41195
    3340 1490
    2828 875
    5372 875
    4860 1490
    3340 1490
    2828 875
    Just a follow up question.
    How come that if using "cell_name -drc yes -cellspace" (w/o -xform) the output will be like this:
     output2:
     CN plc_x1quad c
    3340 1490
    2828 875
    5372 875
    4860 1490
    3340 1490
    2828 875
    5372 875
    4860 1490
    and loading it in RVE will have hierarchical result while in PVS the result is flat and the coordinates in the given cellname in CN points to a wrong place since its reading the coordinates in Flat or in top cell.
    is theres a way that without using "-xform" the output shown above in output2 will be loaded correctly in PVS just like in RVE?.
    Joren
    1
    Not sure - I suggest you contact customer support (I'd have to spend some time putting together an example, and I don't really have time, given that this is not my main area of expertise).
