  3. SPEF file comparison for Calibre xRC and StarRC
  • Views 20761
frasheed
frasheed over 12 years ago
I run the extraction for my project using xRC and StarRC and the extracted file is in SPEF format. Then I compare the SPEF file using myBingo tool to find pin to pin resistance. The problem is the SPEF files are different for some nets ,
Example:
in xRC the net is IP1/@2 112.31 90.31 and second net is IP1/@4 112.31 91.20
in StarRC the net is IP1/@4 112.31 90.31 and seconf net is  IP1/@2 112.31 91.20
 Somehow the co-ordinates or name changes for both, This causing the problem for myBingo as it can't compare the nets  and it just skip it considering it to be a different net.
Any solution for that ? Any configuration through which I can write the SPEF file like StarRC ?
    Given that you're comparing the results of two non-Cadence tools (one from Mentor, one from Synopsys) with a third non-Cadence tool (myBingo - not familiar with where that comes from), this doesn't seem the best place to ask this question! Presumably a Mentor forum would be better since you're asking for a way to write out the xRC output differently.
  • frasheed
    I am so sorry for that , I got confused between Cadence and Calibre , Can you please delete this thread
    No problem - I'll leave it here because if anyone encounters it in future, they might also realise that asking elsewhere is a better option for similar questions.
