  3. OCEAN SCRIPT for getting dynamic energy consumption
  • Views 17667
Carmichaeli
Carmichaeli over 12 years ago
Hi everyone,
I designed a circuit through cadence virtuoso and extracted the spice netlist (.scs) from the ADE. Then I want to do circuit simulation many many times with different input variables by OCEAN SCRIPT. I know a little about the Ocean Script on how to use the For Loops, but I don't know how to get the dynamic energy consumption just by coding in ocn file.
It seems that the ADE can generate an ocean script file for one state automatically. If I use the calculator, the value of dynamic consumption can be calculated and shown in the Result Display Window by click "Tools" -> "Table" in the calculator window (I use average(i("/V0/PLUS" ?result "tran-tran"))*1.8 to get the value). But after saving (in ADE), I can't find any code segment containing this part (like integ, average or other computation) in that ocean file (also can't find them in the spectre netlist I just extracted). The spectre netlist and ocean script file seems just gave me the settings about this simulation or generated the psf file. I just can get the correct result through the calculator way. If I add my own code I always get zero.
Can anyone help me get the dynamic consumption in the ocean script way or give me a few examples?
Thank you extremely!
Here is ocn file,
simulator( 'spectre )
design( "/homes/grad/cadence/Design/inverter_simulate/simulation/inverter_simulate/spectre/schematic/netlist/netlist")
resultsDir( "/homes/grad/cadence/Design/inverter_simulate/simulation/inverter_simulate/spectre/schematic" )
modelFile(
    '("/homes/grad/cadence/models/spectre/tsmc20N.m" "")
    '("/homes/grad/cadence/models/spectre/tsmc20P.m" "")
analysis('tran ?stop "30n"  )
envOption(
'analysisOrder  list("tran")
save( 'v "/out" "/in")
temp( 27 )
run()
    If you add the expression from the calculator into the ADE outputs (Outputs->Setup), then it would also appear in the saved OCEAN script.
    You could also just add:
    ocnPrint( average(i("/V0/PLUS" ?result "tran-tran"))*1.8 )
    into your OCEAN script after the run(). Or whatever expression you're using in the calculator. ocnPrint will print to the screen, but can also be given arguments to get it to print to a file (see the documentation for more details).
  • Carmichaeli
    Thank you for your reply and it's helpful!
    I met another problem. I want to design another circuit which is not based on virtuoso. I mean I just wrote the circuit netlist directly on a blank text document by hand. Then I also wrote an ocean document(.ocn) by hand and found immediately that another file (input.scs) is required (but may not appear in ocean script file(.ocn). Later, it run and generated the psf, but some errors appeared like "The output '/V0/PLUS' you selected does not exist."
    The simulation works good when I use the ocn file that is extracted automatically from ADE. So, do I need some other documents to do the simulation which is just in the Ocean environment?
    design( "/homes/cadence/research/exam/netlist")
    resultsDir( "/homes/cadence/research/exam" )
    modelFile( '("$CDK_DIR/models/spectre/nom/models.scs" "") )
    out = outfile("/homes/cadence/research/exam/mresl_t.txt" "w")
    for( cntrl 1 8 analysis('tran ?stop "30n" )
    desVar( "vq" 1.0+0.1*cntrl )
    envOption( 'analysisOrder list("tran") )
    save( 'i "/V0/PLUS" )
    temp( 27 )
    run()
    openResults("/homes/cadence/research/exam/psf")
    selectResult('tran) linshi=1.0+0.1*cntrl
    dec = (average(i("/V0/PLUS" ?result "tran-tran")) * linshi)
    fprintf(out "%f\n" dec) )
    close(out)
    Thank you so much!
    Wayne.
    ShawnLogan over 12 years ago
    Dear Wayne,
     In line 2 of your script, the netlist location is shown as /homes/cadence/research/exam/netlist. I think if you examine the ocean script generated in the ADE, the ocean script design() command will point to the netlist file contained within the netlist directory - something like design("/homes/cadence/research/exam/netlist/netlist"). Without the netlist directory at the same level as the psf directory *your resultsDir()", the name of your signal in the psf simulation data may not be the same as the that of the schematic hierarchy since the amap directory within the /netlist directory - which provides that link - is missing.
    You can check this by including the ocean command outputs() after loading the results directory and selecting the transient results.
    There is an amaps directory in the /netlist directory that maps node names and when you run ADE, it is invoked so you can plot the signal name  /V2_OUTP_Q/PLUS. When you run standalone ocean, if it does not know the location of the netlist directory, it may not have access to that file. Hence, the node name to access the signal is different than the hierarchical nde name. To avoid this issue, the entire netlist directory should be on the same directory level as the /psf directory. A possible workaround provided by Cadence is to create a soft link to the netlist directory that appears on the same level as your /psf directory. This can be done with the ocean system() command. An example is:
    system("ln -s <path1>/netlist <path2>/netlist")
    where <path1> is the location of your /netlist directory and <path2> is the location of your /psf directory. This will place a symbolic link of the /netlist directory adjacent your existing /psf directory.
    I hope this helps.
    Shawn
  • Carmichaeli
    Hi Shawn,
    You are right. The netlist location is really a problem.
     Thank you so much!
    Best Regards,
    Wayne.
