  3. Built-in Power Calculation
  • Views 15408
moralope
moralope over 12 years ago
I am trying to find out how Cadence calculates the "pwr" operating point parameter of a MOS transistor, and it is almost imposible to get that information.
In a previous forum, it was mentioned that the "pwr" was calculated by the transistor model and not by Spectre. However, I cannot find any information of power calculation in the BSIM4 model for example.
I want to get this information because I have observed that the power calculation in Cadence does not have into account leakage currents (e.g. gate-tunneling current), which are not negligible in scaled technologies. For example, when simulating a large MOS cap, the reported "pwr" is 0, while it is consuming quite some current. Thus, the total "pwr" does not match the power reported by the VDD source.
I have found a paper that reports this issue:
ihome.ust.hk/.../j16.pdf
But still it is not clear for me who has to solve this issue (foundry, BSIM4, Cadence?) and how. Is there a way to include these contributions to the "pwr" calculation of individual transistors?
As I am simulating a quite large circuit and I want to find out the power consumption of each subcircuit, I cannot check manually each transistor to do that calculation.
 moralope
    Moralope,
    In the MMSIM11.1 and MMSIM12.1 documentation, the Device Model Equations manual does list (for bsim4) the equations used to compute the operating point parameters. For pwr, it says:
    49 pwr (W)
    Power at op point. pwr = abs(ids * vds) + abs(ibulk * vbs).
    Unfortunately these equations have gone missing in MMSIM13.1 documentation. I filed a CCR about that a few weeks ago (CCR number 1287725).
    If there's anything wrong with this calculation, then it is the implementation of the model in the simulator that needs to be fixed - so you should contact customer support.
    Kind Regards,
  • moralope
    Thaks Andrew. I have contacted the custumer support.
    moralope
