  3. iscape doesn't run in 64bit amd processor
  • Views 4515
Cold
Cold over 12 years ago
I am experiencing a problem while trying to run iscape (recently downloaded from cadence website) in my 64 bit amd processor with Ubuntu 14.04 Lts amd 64bit installed in it. The error goes as follows.
pavan@pavan-pc:~/cadence/iscape.04.23-s004/bin$ ./iscape.sh
Initializing InstallScape using JVM at /home/pavan/cadence/iscape.04.23-s004/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/pavan/cadence/iscape.04.23-s004/runtime/LNX86/lib/i386/xawt/libmawt.so: libXext.so.6: cannot open shared object file: No such file or directory
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    at java.lang.ClassLoader.loadLibrary(Unknown Source)
    at java.lang.Runtime.load0(Unknown Source)
    at java.lang.System.load(Unknown Source)
    at java.lang.Runtime.loadLibrary0(Unknown Source)
    at java.lang.System.loadLibrary(Unknown Source)
    at sun.security.action.LoadLibraryAction.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.awt.Toolkit.loadLibraries(Unknown Source)
    at java.awt.Toolkit.<clinit>(Unknown Source)
    at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:107)
 Please suggest me a solution for running iscape on my 64bit system.
    First of all, Ubuntu is not a supported operating system for Cadence tools. See platform support.
    However this is probably easily solved by installing the 32-bit version of libXext.so.6. On my 64-bit RHEL6 machine, this is at /usr/lib/libXext.so.6 and is available in the 32-bit version of the libXext-1.1-3.el6.i686 RPM.
    It's OK to have 32-bit packages installed on a 64-bit OS (not the other way around though).
  • Cold
    Thanks andrew
    Iscape worked fine after installing the libXext.so.6.
  • Cold
    when iscape is run and i tried to do a Local/Media install, by selecting cadence IC615 directory. But it does not show any packages on clicking next, and in the terminal i get the following message.
    I recently downloaded this version of installscape(iscape.04.23-s004) from cadence website.
    Use -help option for details on usage....
    com.khanpur.util.parser.ISDOMCreationException: Could not create Document from file /home/pavan/cadence/Cadence_IC6.15_Virtuoso/Hotfix_IC06.15.511-615_lnx86.sdx
    You might be using an older version of InstallScape.
    Ensure that you are using the latest version of InstallScape.
    at com.khanpur.util.parser.KPDomCreator.create(KPDomCreator.java:151)
    at com.khanpur.component.ComponentFactory.create(ComponentFactory.java:164)
    at com.khanpur.installerng.Location.populateWithXml(Location.java:759)
    at com.khanpur.installerng.Location.populateLocationIComp(Location.java:605)
    at com.khanpur.installerng.SourceLocation.populateLocationIComp(SourceLocation.java:240)
    at com.khanpur.installerng.ArchiveLocation.populateLocationIComp(ArchiveLocation.java:191)
    at com.khanpur.installerng.ArchiveLocationManager.locationICompSelected(ArchiveLocationManager.java:168)
    at com.khanpur.installerng.Installer.archiveLocationICompSelected(Installer.java:1127)
    at com.cadence.mediagen.ISSearchDataGenerator.createSearchDataMedia(ISSearchDataGenerator.java:108)
    at com.khanpur.installer.gui.nginterface.ISControlFileToSearchDataTranslator.translateMedia(ISControlFileToSearchDataTranslator.java:86)
    at com.khanpur.installer.gui.nginterface.ISClassicView.mediaLocation(ISClassicView.java:1691)
    at com.khanpur.installer.gui.nginterface.ISClassicView.right_media_location(ISClassicView.java:1015)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.khanpur.installer.gui.nginterface.ISCVBottomButtonBar.callMethod(ISCVBottomButtonBar.java:105)
    at com.khanpur.installer.gui.nginterface.ISCVBottomButtonBarButton.actionPerformed(ISCVBottomButtonBarButton.java:32)
    at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
    at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
    at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
    at java.awt.Component.processMouseEvent(Unknown Source)
    at javax.swing.JComponent.processMouseEvent(Unknown Source)
    at java.awt.Component.processEvent(Unknown Source)
    at java.awt.Container.processEvent(Unknown Source)
    at java.awt.Component.dispatchEventImpl(Unknown Source)
    at java.awt.Container.dispatchEventImpl(Unknown Source)
    at java.awt.Component.dispatchEvent(Unknown Source)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
    at java.awt.Window.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.access$000(Unknown Source)
    at java.awt.EventQueue$1.run(Unknown Source)
    at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
    at java.awt.EventQueue$2.run(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
    Caused by: java.io.FileNotFoundException: /home/pavan/cadence/Cadence_IC6.15_Virtuoso/Hotfix_IC06.15.511-615_lnx86.sdx (No such file or directory)
    at java.io.FileInputStream.open(Native Method)
    at java.io.FileInputStream.<init>(Unknown Source)
    at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
    at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source)
    at java.net.URL.openStream(Unknown Source)
    at org.apache.crimson.parser.InputEntity.init(InputEntity.java:209)
    at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java:470)
    at org.apache.crimson.parser.Parser2.parse(Parser2.java:304)
    at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl.java:433)
    at org.apache.crimson.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:179)
    at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
    at com.khanpur.util.parser.KPDomCreator.create(KPDomCreator.java:141)
    ... 54 more
    The clue is this line:
    My guess is that you're trying to install using an existing Cadence installation, rather than the source media. That makes no sense - there's no need to install it if it's already installed...
    The source media would have a set of sub-directories called CDROM1, CDROM2 etc.
    Alternatively you can download directly from downloads.cadence.com which means that you don't have to download all the hotfix and base media first - it will smartly download what it needs. You can do that with the installscape that  you've already downloaded.
