  3. Regarding : PVS - QRC RUN FAILURE
  • Views 4992
narendra046
narendra046 over 12 years ago
 HI All,
 Newly I made PVS drc & lvs and QRC setup for new technology(gf28nm).
 PVS version - Version        : 12.1.1-p076
 QRC Version        : 10.1.0-s231
When I'm running PVS - QRC through QRC menu, It was failed and showing error like..,
All device symbols for the extracted view are present.
INFO (LBRCXU-114): Finished /chicago/tools/cadence/IC6150/bin/qrcToDfII
INFO (LBRCXM-642): Constructing the RCX run script
INFO (RCXSPIC-28057): RCXspice: unrecognized variable 'CFITABLE' in file '/remote2/test_proj/analog_project/gf28hp/release/qrc/5U1x_1T8x_LB/nominal/RCXspiceINIT'
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
  Please let me know any suggestions to resolve this issue.
 Thanks in Advance.
Narendra
  • Quek
    Quek over 12 years ago
    Hi Narendra
    It means that your current version of QRC is older compared to the version which Globalfoundries had used to prepared the QRC package. The problem can be easily resolved by switching to a newer version of QRC (e.g. QRC14.1).
    Best regards
    Quek
  • narendra046
     Thanks Quek for your valuble suggestions.
    Now QRC was almost run after installed qrc newer version(EXT13.2).  But, At the end of qrc run it was failed and showing error like..,
    ENDCAT
    cat \
            /remote2/test_proj/analog_project/GF/VIRTUOSO/LVS_QRC/svdb/test/hccisavefile \
            >> _save_layers
    INFO (LBRCXM-610): Extraction finished.
    INFO (LBRCXU-108): Starting
     /chicago/tools/cadence/IC6150/bin/qrcToDfII -extract both -run_name test -cdlout_run_dir /remote2/test_proj/analog_project/GF/VIRTUOSO/LVS_QRC -check_cell_view FALSE -device_finger_delimiter @ -extracted_view av_extracted -lvs_source agds -cap_models no -capacitor pcapacitor -res_models no -resistor presistor -cap_prop_name c -res_prop_name r -extview_tmp /remote2/test_proj/analog_project/GF/VIRTUOSO/LVS_QRC/svdb/test/extview.tmp -run_dir /remote2/test_proj/analog_project/GF/VIRTUOSO/LVS_QRC/svdb/test -lib_name narendra -cell_name test -view_name layout -extview_rul /remote2/test_proj/analog_project/GF/release/qrc/extview.rul -server /remote2/tools/cadence/EXT13.2/tools.lnx86/extraction/bin/32bit//../shapeServer
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.16s.
    exec: /remote2/tools/cadence/EXT13.2/tools.lnx86/extraction/bin/64bit/shapeServer: cannot execute [Exec format error]
    Failed to start QRC module 'shapeServer'. Please check QRC installation or contact Cadence Customer Support.
    INFO (LBRCXU-111): Warning /chicago/tools/cadence/IC6150/bin/qrcToDfII exit with bad status
    INFO (LBRCXU-112): Warning Status 256
    INFO (LBRCXU-113): Warning QRC execution terminated
    *****  aveng fork terminated abnormally  *****
    Please help me to resolve this issue. Thanks in advance.
    Regards Narendra
    What OS distribution are you using? And what does "uname -a" report?
  • narendra046
    Sorry for late reply.
    "uname -a" report on my side is -
    Linux blue 2.6.32-431.el6.i686 #1 SMP Fri Nov 22 00:26:36 UTC 2013 i686 i686 i386 GNU/Linux
    Thank you
    Narendra
    Narendra,
    It looks as if you're using a 32-bit OS (although probably a RHEL6 flavour - you didn't say - given the kernel subversion). Generally speaking we don't support 32-bit OS for recent releases of the software, so the best thing to do is to update to a 64-bit OS.
    I took a quick look, and initially thought by setting $CDS_AUTO_64BIT to "none" or "NONE" you could force QRC to run in 32-bit mode (the default for QRC is 64-bit. However, it appears that on RHEL6.1 and RHEL6.3 (i.e. the same region of kernel versions that you're using - RHEL6.3 is kernel  2.6.32-279.el6.x86_64) it always seems to run shapeServer in 64-bit mode even when CDS_AUTO_64BIT is set (the "qrc" executable is OK, but not shapeServer). On RHEL5.8 setting this successfully runs shapeServer in 32-bit mode.
    So you really should run on a 64-bit OS. This can be seen in our platform support matrix.
