  3. dataAuditErrors in standard cells' layout
  • Views 6557
csst
csst over 12 years ago
 Hi all,
I'm trying to run DRC on a GDS file exported from Encounter v10.12-s181_1
using umc65 standard cell library.
When I run DRC, I get dataAuditErrors in avPart## and various cells.
Tools have been used are
IC sub-version 5.10.41.500.6.143
Assura sub-version 4.1_USR4
In Assura's documentation (Assura Physical Verification Developers Guide)
it says that "The Assura program accepts self-intersecting shapes and tries to generate valid shapes during the merging process.
 If you use the DRC raw modifier, the tool will not try to merge the shapes."
  will DRC raw modifier fix it and how do I set it on?
As shown in CDS.log these errors are Self-overlapping paths.
Moreover the avPart## error, in all cases, it is a Metal1 stripe inside a Pi-shaped Metal1 in a standard cell.
Is it possible to fix these errors?
Regards
 CDS.log:
Compiling rules...
\o
\o WARNING Undefined layer in dfII.
\o     Layer name 'VI10' doesn't exist, treating as an empty layer.
\o     VI10 = layer("VI10" type("drawing"))
\o
\o     Layer name 'ME11' doesn't exist, treating as an empty layer.
\o     ME11 = layer("ME11" type("drawing"))
\o
\o     Layer name 'M11_CAD' doesn't exist, treating as an empty layer.
\o     M11DMBK = layer("M11_CAD" type("Dummy_Block"))
\o
\o     M11DUMY = layer("M11_CAD" type("Dummy"))
\o
\o     M11SLOT = layer("M11_CAD" type("Slot"))
\o
\o     VI10BAR = layer("VI10" type("BAR"))
\o
\o WARNING Undefined purpose in dfII.
\o     Purpose name 'SP_6' doesn't exist, ignoring this purpose.
\o     SP_6 = layer("SP" type("SP_6"))
\o
\o     Purpose name 'SP_9' doesn't exist, ignoring this purpose.
\o     SP_9 = layer("SP" type("SP_9"))
\o
\o     Layer name 'SP2_Q' doesn't exist, treating as an empty layer.
\o     SP2_Q = layer("SP2_Q" type("drawing"))
\o
\o     Layer name 'RF1_MTK' doesn't exist, treating as an empty layer.
\o     RF1_MTK = layer("RF1_MTK" type("drawing"))
\o
\o     M11_TEXT = textToPin("M11_CAD" type("TEXT"))
\o
\o     M11_TEXTT = textToPin("ME11" type("drawing"))
\o
\o     M11_PIN = pinText("ME11")
\o
\o function rectangle_enclosure redefined
\o function density_window redefined
\o function density_within_window redefined
\o
\w *WARNING* Self-overlapping path: layer ME1 in "ADFM2NA layout umc65ip" at 0.56:0.26.
\w Moved to dataAuditError layer
\o Creating verification cell   ADFM2NA layout umc65ip
\w *WARNING* Self-overlapping path: layer NWEL in "AO22M1NA layout umc65ip" at -0.36:0.81.
\o Creating verification cell   AO22M1NA layout umc65ip
\w *WARNING* Self-overlapping path: layer NWEL in "AOI22M8NA layout umc65ip" at -0.36:0.81.
\o Creating verification cell   AOI22M8NA layout umc65ip
\w *WARNING* Self-overlapping path: layer DIFF in "CKBUFM48N layout umc65ip" at 2.205:0.2.
\o Creating verification cell   CKBUFM48N layout umc65ip
\w *WARNING* Self-overlapping path: layer DIFF in "NR4B1M4N layout umc65ip" at 0.065:0.97.
\o Creating verification cell   NR4B1M4N layout umc65ip
\w *WARNING* Self-overlapping path: layer ME1 in "NR4M4NA layout umc65ip" at 0.235:0.66.
\o Creating verification cell   NR4M4NA layout umc65ip
\w *WARNING* Self-overlapping path: layer ME1 in "SDFCQRM2NA layout umc65ip" at 0.445:0.675.
\o Creating verification cell   SDFCQRM2NA layout umc65ip
\w *WARNING* Self-overlapping path: layer ME1 in "XOR3M2NA layout umc65ip" at 3.23:0.27.
\o Creating verification cell   XOR3M2NA layout umc65ip
Assura's .err file
Rule No. 1 : dataAuditErrors
Real Error Count : 53; Flat Error Count : 8675
Cell Name : avPart125
                   Cell Errors    Real Errors   Cell Placements     Environments
                             1              1                43                1
Env.  Env. Placements            X1           Y1          X2           Y2
  1       43                 79.620      437.460      79.755      437.925
Shape               Environments Status & Error Marker
          1           X1         Y1         X2         Y2
   1      X       -0.580      0.675     -0.445      1.140
Error Layer Window:
Total SignOff:           0
Total Fixed:             0
Rules Filter:
Cells Filter:
Real Error Count :   58; Flat Error Count : 8679
Cell Name : avPart57
           Cell Errors:       2    Real Errors:       2
Cell Name : avPart34
Cell Name : avPart69
Cell Name : avPart21
Cell Name : avPart14
Cell Name : avPart10
Cell Name : avPart112
Cell Name : avPart110
Cell Name : avPart92
Cell Name : avPart9
           Cell Errors:       1    Real Errors:       1
Cell Name : avPart33
Cell Name : avPart8
Cell Name : avPart4
Cell Name : avPart17
Cell Name : avPart18
Cell Name : avPart20
Cell Name : avPart1
Cell Name : XOR3M2NA layout umc65ip
Cell Name : avPart24
Cell Name : avPart26
Cell Name : avPart27
Cell Name : avPart30
Cell Name : ADFM2NA layout umc65ip
Cell Name : SDFCQRM2NA layout umc65ip
Cell Name : avPart23
Cell Name : avPart47
Cell Name : avPart54
Cell Name : avPart55
Cell Name : AO22M1NA layout umc65ip
Cell Name : avPart62
Cell Name : avPart68
Cell Name : avPart40
Cell Name : avPart74
Cell Name : avPart76
Cell Name : avPart77
Cell Name : avPart99
Cell Name : avPart79
Cell Name : avPart95
Cell Name : avPart96
Cell Name : avPart97
Cell Name : avPart89
Cell Name : avPart102
Cell Name : avPart105
Cell Name : avPart106
Cell Name : avPart109
Cell Name : avPart88
Cell Name : avPart111
Cell Name : avPart85
Cell Name : avPart117
  • csst
    Solved
    For anyone else having the same problem
    Open the faulty cell with the dataAuditErrors, locate the faulty layer and then
    go to Edit Polygon Properties and fix 'Points'
    for example the points for a faulty metal1 rectangle were
    Points (-10.57 1.27) (-10.57 2.53) (-10.45 2.53) (-10.45 1.47) (-10.45 1.48) (-10.45 1.49) (-10.45 1.5) (-10.45 1.51) (-10.45 1.53) (-10.45 1.57) (-10.45 1.52) (-10.45 1.57) (-10.45 1.53) (-10.45 1.55) (-10.45 1.5) (-10.45 1.47) (-10.45 1.54) (-10.45 1.51) (-10.45 1.51) (-10.45 1.56) (-10.45 1.5) (-10.45 1.55) (-10.45 1.51) (-10.45 1.6) (-10.45 1.51) (-10.45 1.48) (-10.45 1.52) (-10.45 1.49) (-10.45 1.51) (-10.45 1.59) (-10.45 1.53) (-10.45 1.5) (-10.45 1.51) (-10.45 1.56) (-10.45 1.51) (-10.45 1.48) (-10.45 1.51) (-10.45 1.49) (-10.45 1.52) (-10.45 1.52) (-10.45 1.53) (-10.45 1.52) (-10.45 1.51) (-10.45 1.62) (-10.45 1.5) (-10.45 1.54) (-10.45 1.5) (-10.45 1.5) (-10.45 1.54) (-10.45 1.53) (-10.45 1.53) (-10.45 1.53) (-10.45 1.52) (-10.45 1.51) (-10.45 1.53) (-10.45 1.58) (-10.45 1.53) (-10.45 1.51) (-10.45 1.52) (-10.45 1.55) (-10.45 1.5) (-10.45 1.54) (-10.45 1.52) (-10.45 1.53) (-10.45 1.51) (-10.45 1.62) (-10.45 1.53) (-10.45 1.58) (-10.45 1.53) (-10.45 1.56) (-10.45 1.53) (-10.45 1.62) (-10.45 1.47) (-10.45 1.47) (-10.45 1.5) (-10.45 1.47) (-10.45 1.5) (-10.45 1.48) (-10.45 1.49) (-10.45 1.61) (-10.45 1.5) (-10.45 1.47) (-10.45 1.5) (-10.45 1.54) (-10.45 1.62) (-10.45 1.63) (-10.45 1.64) (-10.45 1.65) (-10.45 1.27)
    and it should be
    (-10.57 1.27) (-10.57 2.53) (-10.45 2.53) (-10.45 1.27)
    just erase the redundant points which are considered invalid graphics data
