  3. model file
  • Views 16897
model file
auto dipper
auto dipper over 12 years ago
Hi Aandrew .
as per your comment @
i have started that conversation in this new post. i hope this is the way you desired ? below is the question i had posted in the previous post related to this topic.
"Hi all,
I have an accademic level spice model file for nmos and pmos. I want toinclude this file in the model library path for simulation purposes.Although i have included it in ADE by Setup-> model libraries buti am still getting the below error after netlist & run -
“ERROR(SFE-23): "input.scs" 39: M0 is an instance of an undefinedmodel equal_vt0”
whereequal_vt0.m is the name of the model file."
Actually i have included the models for ami06N & ami06P so errors with respect to those have got removed but i want to replace all the ami06N nmos4 models with a nmos model whose model file is as attached with this comment. So how can it be done. I tried to use a general nmos from AnalogLib and enter parameters (source permeter etc..) into it as per this file but then i got the error as i mentioned first in this comment.
Regards
  • equal_vt0.txt
    But you still have:
    .model equal_vt0 nmos4 ...
    but it should be (as I said earlier in this confusing thread):
    .model equal_vt0 nmos ...
    It's not surprising that it doesn't work since spectre has no primitive called "nmos4".
