  3. Creating Parametrized Symbol
  • Views 16268
RFStuff
RFStuff over 12 years ago
 Dear All,
I created a symbol form my schematic which has some parmeters in it.
Basically, the schematic has 4 voltage sources ( 4 vdc). The DC voltages are parametred as  BIT_0,BIT_1,BIT_2 and BIT_3.
When I instantiate the symbol, I need to have these voltages appearing as parameters in the symbol prompt ( like vbit has parameters like tr,tf,v0,v1...etc). I don't want these parameters appearing as parameters in ADE.
Could anybody please tell how it can be done ?
Kind Regards,
    In your schematic with the voltage sources, make the parameterized values pPar("BIT_0"), pPar("BIT_1") etc. This makes them inherited parameters rather than global parameters.
    If you've already created the symbol (and CDF) for this parameterized block, then with the schematic open and the current window, type in the CIW:
    artGenerateHierSymbolCDF(geGetEditCellView())
    Then you can go to Tools->CDF->Edit CDF, set the CDF type to "Base" and pick the lib/cell of your parameterized component. You can then change the prompts and default values for the parameters you have.
    Then when you place an instance of this cell, you can override the default values on the instance.
    Hope that's clear.
    Kind Regards,
  • RFStuff
     Dear Andrew,
    Thanks a lot for your reply.
    In the same way if I use vbit instead of vdc and use pPar("BIT_0")....pPar("BIT_3") in the pattern parameter data and then use 4 patterns stored in a model file, it should work ?
    Kind Regards,
    This should work.
