  3. Annoying message about OS compatibility and SKILL IDE p...
  • Views 16611
Annoying message about OS compatibility and SKILL IDE problem
Kovinko
Kovinko over 12 years ago
 Hi all,
I have two questions, please can you give me an advice?
The first:
 Please how can i suppress the annoying message about operational system compatibility with DFII? In concrete i talk about this message
"WARNING: HOST <eda-laptop> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>."
which appear in CIW also in terminal many times. Exist some environment variable that can eliminates only this message? The virtuoso is installed on opensuse 13.1.
The second:
Do you know why I can't launch SKILL IDE? I go to TOOLS->SKILL IDE. After activate this item, in CIW i get "Loading skillDev.cxt" output message but nothing happened, no error message, no popup windows, just nothing. Is it installation problem? Administrator claim that license should be OK.
 Thanks a lot for your advices and response.
  • Quek
    Quek over 12 years ago
    Hi Kovinko
    1. You can disable the warning message using the following shell variable:
    setenv W3264_NO_HOST_CHECK 1
    Please see COS article 20159321.
    2. Would you please execute the following cmd in a terminal window to check if you really have the license?
    terminal>lmdiag -c $LM_LICENSE_FILE skillDev
    OR
    terminal>lmdiag -c $CDS_LIC_FILE skillDev
    Best regards
    Quek
    Just noticed this is a duplicate post of this one.
