  3. OSS netlisting inherited gnd problem
  • Subscribers 133
  • Views 15350
freitas
freitas over 12 years ago
Dear all,
we are having a strange issue when netlising our design with the OSS netlister (via runams command-line).
Some of the inherited grounds nets are being strangely netliested. For instance, an inherited net that should be netlisted as \vss! ; is being netlisted as \vss_vss! ;  that is, its name is being duplicated. This causes elaboration errors.
Here's what we see:
 // Verilog-AMS netlist generated by the AMS netlister, version 5.10.41.500.6.149.
// Cadence Design Systems, Inc.
(* cds_ams_schematic *)
module and2_2 ( x,a,b );
 output   x;  input   a;  input   b;
 wire (*
integer inh_conn_prop_name = "vdd";
integer inh_conn_def_value
= "cds_globals.\\vdd! ";
\vdd! ;
wire (*
integer inh_conn_prop_name = "vss";
= "cds_globals.\\vss! ";
\vss! ;
  \nmos  #(.ad(( max(1.120 , 0.7) * 0.805 )), .nrd(( 0.28 / 1.120 )), .vds("2.5"),
.pd(( 2.0 * ( max(1.120 , 0.7) + 0.805 ) )), .w(1.120), .lpe(0), .as(( max(1.120 , 0.7) * 0.805 )),
.nrs(( 0.28 / 1.120 )), .np(1), .ps(( 2.0 * ( max(1.120 , 0.7) + 0.805 ) )),
.l(0.28)) (*
integer library_binding = "smos8mv_ams";
N53 ( x,
nnet6, \vss! , \vss!  );
\nmos  #(.ad(( max(0.630 , 0.7) * 0.805 )), .nrd(( 0.28 / 0.630 )), .vds("2.5"),
.pd(( 2.0 * ( max(0.630 , 0.7) + 0.805 ) )), .w(0.630), .lpe(0), .as(( max(0.630 , 0.7) * 0.805 )),
.nrs(( 0.28 / 0.630 )), .np(1), .ps(( 2.0 * ( max(0.630 , 0.7) + 0.805 ) )),
.l(0.28)) (*
using runams (OSS NETLISTER), FOR THE SAME “AND2_2”, I got a different format netlist, which gave ncelab errors.
2)      ---------------------
module and2_2 (x, a, b);
output  x;
input  a, b;
wire (*
integer inh_conn_def_value = "cds_globals.\\vdd! ";*)
cdsNet1;
wire (*
integer inh_conn_def_value = "cds_globals.\\vss! ";*)
cdsNet0;
wire (*
\vss_vss! ;
\nmos #(.l(0.28), .w(1.120), .as("(max((1.120),0.7)*0.805)"),
    .ps("(2.0*(max((1.120),0.7)+0.805))"),
    .ad("(max((1.120),0.7)*0.805)"),
    .pd("(2.0*(max((1.120),0.7)+0.805))"), .nrd("(0.28/(1.120))"),
    .nrs("(0.28/(1.120))"), .lpe(0), .np(1), .vds(2.5)) N53 (x, nnet6
    , cdsNet0, \vss_vss! );
So the cdsNet1, cdsNet0, \vss_vss! Are all the ncelab errors.
Any ideas?
thanks for your support.
    Please contact customer support - I think we'll need to look at the data. I didn't do any searching to see if I could find this, and there isn't any opportunity to really fix the software (the last hotfix, 5.10.41.500.6.151 was released over 2.5 years ago), but maybe we can identify something unusual about the data and provide a workaround.
    Kind Regards,
