  3. How to multiply a waveform with the x axis vector
  • Views 19067
milind0y
milind0y over 12 years ago
        I want to multiply the AC response of a node with the frequency. So at each point the voltage is multiplied with the frequency at that point to produce the new wave. How can I do this in the calculator?
Milind
    Milind,
    If your AC response is VF("/out") then this would be VF("/out")*xval(VF("/out")) . The xval() function gives you the x-axis of a waveform.
  • milind0y
    Thanks, that worked.
