  3. PSS Analysis in Corner Simulation
  • Views 15639
YingC
YingC over 12 years ago
Dear,
I wanted to run PSS analysis during corner simulation of an oscillator. However, the beat frequency of the oscillator is a changing value  subjected to corner variations. This means that I cannot set the same beat frequency value for each PSS run.
I assume that I need to perform 2 analysis in sequence during each run:
1. Transient simulation: to calculate the beat frequency
2. PSS analysis using the beat frequency value obtained from step 1.
How can I set these up in the ADE XL environment? Specifically, can I set the PSS beat frequency  as a variable which comes from the result of the Transient simulation? And how?
Best regards,
  • Tom Volden
    Tom Volden over 12 years ago
    There are two ways to accomplish this in ADE XL.
    The first is to have two tests - one for the transient simulation and one for the PSS simulation.  In the transient simulation test create a measurement to calculate the beat frequency and then assign this measured value to a global variable which will be used for the beat frequency in the second test using something like calcVal("beat_freq").  This will create a dependency between the two tests so ADE XL will run the transient test first followed by the pss test.
    The second approach is to use a pre-run script.  In this case you would have only one test.  The pss analysis would be set up in the test with a global variable for the beat frequency.  The pre-run script would be used to run the transient analysis and feed the beat frequency value to the variable.
    Both of these methods are described in more detail in the white paper titled "Calibrated Verification with ADE XL" which you can find on the support.cadence.com website at the following link: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000050aREAQ&pageName=ArticleContent
    TOM
    However,  in general PSS does not need the estimated frequency to be that accurate so I'm not sure why you need to do this. Tom's advice is of course good, but I'd be surprised if it is necessary. What sort of range is the frequency varying over? I'm assuming you do actually have the "oscillator" checkbox turned on for the PSS analysis?
