  3. Link pin labels over hierarchy
  • Views 15621
Narasimhan90
Narasimhan90 over 12 years ago
I want to know if it is possible to link labels of instances to the labels in the top module, so that if I change the position of a label in the individual blocks it should get reflected in the top module.
Here is an example.
I create a layout of a cell with two labels say Vin and Vout(labels are created with layer "metal pins" correponding to the "metal drawing").
In the top module I instantiate two such cells. And label them as Vin1, Vin2, Vout1 and Vout2.
Now I want to link the Vin1 and Vin2 to the underlying Vin so that in future if I change the cell such that the location of Vin changes, the locations of Vin1 and Vin2 should also chage accordingly in the top module. This helps me save time since I need not do it again in the top module manually.
Ofcourse the above is just an example. When I have say 15 such cells with quite a few labels each, it takes an awful long time to move the labels for a simple chage in the cell(like moving a single wire).
I am using layout L. If it is not possible in layout L, will layout XL solve my problem? Or do I need to learn SKILL and try it?
Thanks.
    I don't believe there is any built-in capability to do this. You would probably have to write some SKILL code to store some property on each of the top level labels to indicate which hierarchical label you want to reference, and then have some SKILL code to visit each of these labels and update their position based on the current position of the lower level labels. It wouldn't happen automatically though - you'd have to run something to update the top level label positions.
  • Narasimhan90
    Thanks for the reply. I am planning to learn SKILL in the near future. But currently I can manage with the manual process since even if I have written SKILL code, it will take a while to completely test, trust and rely on it.
    On a side note: The topic says 0 views? How can the views be 0 if a person has viewed and replied (I have also viewed it a few times from my PC and phone).
    I've asked the IT team who do the administration of the forums to look into this (they are also looking into why some of us are getting multiple email notifications of each post).
