  3. ADEXL: Post-Processing Ocean Scripts - Results Access
  • Views 3299
ronanc
ronanc over 12 years ago
I would like to call an ocean script I have that in turn calls an Octave (Matlab alternative) script.
I’d like my ADEXL corner simulations to automatically launch this ocean script, post process
each individual corner, and then read back in the text file that’s output by Octave.
I’ve managed to launch a simple Ocean script by adding it to my outputs in my ADEXL session,
but I’m not sure how to access the results database. The axlCurrentResultsPath variable does not appear
to be set. Also, axlGetMainSetupDB requires a “session name”, which to me seems will change each
time I run a new batch of corners.
Any help would be greatly appreciated. Thanks.
Best regards,
Ronan
    Ronan,
    axlCurrentResultsPath is only supported in Matlab measurements, not in OCEAN. Also, you cannot use the spectre toolbox for Matlab with Octave - whilst Octave has a source code compatible API to add custom commands at the C level, I don't believe you can use a shared library built for Matlab in Octave instead. We do not support a similar toolbox for Octave (mostly because the software license for Octave presents problems for a commercial software company).
    From an OCEAN script, you should be able to call openResults() (with no arguments) to find out where the results directory is - but I'm not sure how this would help you if you were to then invoke Octave from the OCEAN script (e.g. with ipcBeginProcess()), since there's nothing in Octave to read the results database. Maybe you could use OCEAN to access the data you want, write it to an ASCII file (e..g using ocnPrint), invoke Octave to do the post-processing reading from the ASCII file and writing a new one, and then reading that in the OCEAN script. Sounds quite a bit of work...
    There is also the axl API too - but it's not that clear precisely what you're trying to do?
  • ronanc
    Thanks for the swift reply, and sorry for not being so swift myself.
    In the absence of time, I have gone back to command our command-line-based APS simulation method.
    I use octave to perform pole-zero AC fitting, and also DC-curve-fitting  to my APS sim output.
    We do indeed write to / read from waveform files.
    Is there any good curve-fitting tool I can use within Cadence? My colleague tried, but got segmentation errors.
    When I get time I will try  openResults() and ipcBeginProcess()).
    Ronan
