  3. Defining Spacing Rules inside the technology file
  • Subscribers 133
  • Views 15622
archive over 19 years ago
I want to define spacing rules inside the technology file. But if I compile the technology file, I get the following error message:
\o Loading techComp.cxt
\o Compiling class 'controls'....
\o Compiling class 'layerDefinitions'....
\o Compiling class 'layerRules'....
\o Compiling class 'devices'....
\w *WARNING* *Error* eval: undefined function - physicalRules
I defined the spacing rules according the cadence documentation:
physicalRules(
;orderedSpacingRules(
;       ;( rule layer1 layer2 value )
;       ( minEnclosure "cellBoundary" "nwell" 0.1 )
;       ( minEnclosure "ndiff" "cont" 0.5 )
;) ;orderedSpacingRules
spacingRules(
        ( minSpacing "Metal1" "Metal1" 2 )
) ;spacingRules
mfgGridResolution(
        ( 0.100000 )
) ;mfgGridResolution
) ;physicalRules
Does somesome know, what the problem is?
Kind regards,
haikom
Originally posted in cdnusers.org by haikom
    ok, the compilation problem is solved. I switched the order of the class device and physicalRules and then the technology file was compiled sucessfully.
    But now I'm wondering, because the minSpacing at the metal1 layer does not have any effect. I thought that if I draw two paths so that the minSpacing rules is active --> a pop-up window appears! But nothing happened. How can I test the rules?
    Kind regards,
    haikom
    I've answerd this here
    http://www.designers-guide.org/Forum/YaBB.pl?num=1159952487
    Bernd
    Originally posted in cdnusers.org by bernd.fischer
