  3. Substrate is connected to nodes other than VDD or VCC
  • Views 20458
csst
csst over 12 years ago
Dear All
In a standard cell library,  VBP and VBN is used for substrate in schematic
but  layout uses only VDD VSS and you have to add normal well taps.
I get this error in LVS
Rule No.   20 : Please Note that NWEL is connected to nodes other than VDD or VCC
Rule No.   19 : Please Note that PSUB is connected to nodes other than GND or VSS
How it can be fixed?
Same error when i pass, in netlist, VDD in VBP, and VSS in VBN
IC sub-version 5.10.41.500.6.143
Assura sub-version 4.1_USR4
Regards
  • csst
    I've noticed that compare.rul file has these lines
    PWR1 = "*VDD*"
    PWR2 = "*VCC*"
    GND1 = "*GND*"
    GND2 = "*VSS*"
    ; Check if  NWEL is connected to VDD or VCC.
     wela = geomGetNet( wel PWR1 PWR2 )
     wel_wrong = geomAndNot( wel wela )
     errorLayer( wel_wrong "Please Note that NWEL is connected to nodes other than VDD or VCC" )
    ; Check if  PSUB is connected to GND or VSS.
     psuba= geomGetNet( PSUB GND1 GND2 )
     psub_wrong = geomAndNot( PSUB psuba )
     errorLayer( psub_wrong "Please Note that PSUB is connected to nodes other than GND or VSS" )
    in geomGetNet() i added "VBP" for NWEL  and "VBN" for PSUB but i'm still getting the same error
     wela = geomGetNet( wel  PWR1 PWR2  "VBP" )
     psuba= geomGetNet( PSUB GND1 GND2  "VBN")
    i've also tried to directly change PWR and GND variables.
    I think it's best to contact customer support or the foundry that supplied you with these rules. Hard to debug without seeing the data and the complete rule deck. Note that you originally reported it showing "Rule No. 20" etc in the rule message, but that doesn't appear in the code  you modified - so maybe you edited the wrong place?
  • csst
    csst over 11 years ago
    I've found the solution
    In folder RuleDecks/Assura/LVS
    edit these rule files
    1. In EXTRACT rule file
    ;Detect ptap connected to POWER, please change the power node name if yours is different from VDD and VCC.
    ptap99= geomAvoiding( geomGetNet(ptap, "VDD" "VCC" "VBP" "VDD!")  geomOr( DSYMBOL SEALRMARK PCAPGATE_12 PCAPGATE_18 ) )
    ;Detect ttap connected to POWER, please change the power node name if yours is different from VDD and VCC.
    ttap99= geomAvoiding( geomGetNet(ttap, "VDD" "VCC" "VBP" "VDD!") geomOr( DSYMBOL SEALRMARK PCAPGATE_12 PCAPGATE_18 ) )
    ;Detect ntap connected to GROUND please change the ground node name if yours is different from VSS and GND.
    ntap99= geomAvoiding( geomGetNet(ntap, "GND" "VSS" "VBN" "VSS!") geomOr( DSYMBOL NWR MISIMPBK varmis_rf12 NCAPGATE_12 NCAPGATE_18 ) )
    wela = geomGetNet( wel "VDD" "VCC" "VBP" "VDD!")
    psuba= geomGetNet( PSUB "GND" "VSS" "VBN" "VSS!")
    2. In COMPARE rule file
    schematic(
         setPower( all "*VCC*" )
         setPower( all "*VBP*" )
         setPower( all "*VDD!*" )
         setPower( all "*VDD*" )
         setGround( all "*GND*" )
         setGround( all "*VSS*" )
         setGround( all "*VBN" )
         setGround( all "*VSS!*" )
    layout(
