  3. Parameterize number of iterated instances
  • Views 16162
The Setlaz
The Setlaz over 12 years ago
I'm using IC12 ISR9 and I'm looking for a way of making the number of iterated instances (and its associated bus name) to take a variable instead of an integer.
eg: put N resistors in series using: instance R<N:0>  connected to "Rp, RNext<N-1:0>" on one side, and "RNext<N-1:0>,Rn"  on the other side and being able to set and/or sweep parameter N.
I couldn't find an easy way to do that. Is it even possible ? Or is there any way/workaround to do something similar ?
Damien
PS: I picked a resistor, but the application would be for stacking transistors as the maximum gate length gets smaller and smaller as we go into more advanced process nodes)
    Damien,
    There is no support for this, either in the OA database or the tool. Typically for series connected (or stacked) resistors or transistors this is done with a schematic pcell. For transistors, for some advanced node models, there may be an instance parameter that allows specifying of series connected device (depends on the model used, I think).
