  3. Sweeping Vth vs L
  • Replies 24
  • Views 37200
Sweeping Vth vs L
Arjun RP
Arjun RP over 12 years ago
Hi all,
I am Arjun, Graduate student pursuing IC Design. I am trying to sweep the Vth of transistor with respect to its length. I saved a file with .scs extension and with the content save M0:all. I selected DC analysis and in the sweep i selected component parameter and transistor M0 where i selected its length "l". I also included the .scs file into model library. But when i run the simulation i am getting a error as given below.
ERROR (SFE-430) : 'dc' : Sweeping the parameters of a subcircuit instance ('M0') is currently not supported. Please use the spectre sweep instead.
Spectre terminated prematurely due to fatal error.
 What should i do to overcome this error ? Please help me
  • Arjun RP
    The version is 7.1.1.426.isr27 32 bit as displayed in the spectre.out file. Is there any way to sweep Vth vs L other than running scripts so that i will be easy for me to sweep different transistor's Vth vs L ?
    I tried in that version of spectre, and it also works.
    There's no requirement that you have to run this from the command line - it should work fine from ADE too. I just did it from a netlist because it was quicker for me to throw together an example. Can you share the netlist that you are getting in ADE? Also show the results browser as a screenshot (use the Options tab to attach a picture).
  • Arjun RP
    I have connected just one transistor with two vdc's. In the transistor edit object properties length i have given "length". In ADE L i copied the variables from the cell view. Clicked dc analysis and selected design variable under sweep. Selected the variable name "length". Gave start and stop values. Ran the simulation. I also selected the file mysave.scs in the model library which contains the command as given by you in previous post save *.all devtype=bsim4.
    After i am running the simulation there was no warning and error. I went to results browser and selected dc-dc. I couldnt see the vth of the transistor. I have attached the image with this post describing the things i have done.
    OK, but you didn't post the input.scs (the netlist) which is what I wanted to see...
  • Arjun RP
    This is the file i have added in model library.
    You still didn't show the input.scs (Simulation->Netlist->Display in ADE will show this). Also, paste the contents rather than a screen grab please. You show your include file as "mysave" rather than "mysave.scs" - does it have a ".scs" suffix?
  • Arjun RP
    This is what i get from simulation-->netlist-->display. I dont know how to show include file as mysave rather than mysave.scs. Also uploaded the sceenshot
     // Generated for: spectre
    // Generated on: Aug  6 19:09:59 2014
    // Design library name: Vref
    // Design cell name: test
    simulator lang=spectre
    global 0
    include "/home/palaniapy13/mysave.scs"
    include "models.scs"
    parameters length=1
    // Library name: Vref
    // Cell name: test
    // View name: schematic
    M0 (net6 net3 0 0) nlvtlp w=0.135 l=length nfing=1 mult=1 srcefirst=1 \
            ngcon=1 mismatch=1 lpe=0 dnoise_mdev=0 dmu_mdev=0 dvt_mdev=0
    V4 (net3 0) vsource dc=1 type=dc
    V5 (net6 0) vsource dc=1 type=dc
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    dc dc param=length start=0.5 stop=10 lin=10 oppoint=rawfile maxiters=150 \
    subckts info what=subckts  where=rawfile
    saveOptions options save=allpub subcktprobelvl=2
    I just realised what you problem was after trying loads of different things. I noticed from your screen grab that you had "save *.all" rather than "save *:all" (i.e. dot rather than colon).
    That would explain it.
  • Arjun RP
    Corrected that mistake and now i can plot Vth vs L . Thank you so much for patiently answering all my queries and helping me. Thanks again.
    Regards
    Arjun
  • Arjun RP
    Is there any way to find the Mobility and Cox of the transistor in cadence ?. I am studying about Voltage References. I want to sweep Mobility and Cox with respect to temperature and length. By this way i can learn better about the transistor characteristics ? Please help me.
