  3. Sweeping Vth vs L
  • Replies 24
  • Views 37192
Sweeping Vth vs L
Arjun RP
Arjun RP over 12 years ago
Hi all,
I am Arjun, Graduate student pursuing IC Design. I am trying to sweep the Vth of transistor with respect to its length. I saved a file with .scs extension and with the content save M0:all. I selected DC analysis and in the sweep i selected component parameter and transistor M0 where i selected its length "l". I also included the .scs file into model library. But when i run the simulation i am getting a error as given below.
ERROR (SFE-430) : 'dc' : Sweeping the parameters of a subcircuit instance ('M0') is currently not supported. Please use the spectre sweep instead.
Spectre terminated prematurely due to fatal error.
 What should i do to overcome this error ? Please help me
  • mate0409
    mate0409 over 12 years ago
     Hi Arjun,
     try to use for the length of the device a variable for example 'n_length' (in the 'Edit Object Properties' form). Then choose in the DC analysis form instead of component parameter your design variable (n_length) as sweep variable.
     Regards
  • Arjun RP
    Thanks for replying. How can I sweep Vth wrt L if I add a variable name for length in edit properties of a transistor ? Can you please explain me the steps
  • mate0409
     in ADEL clikc on Variables -> Copy From Cellview to load the length variable. I have attached a picture for the suggested DC analysis setup. Instead of typing the name of the variablein the 'Variable Name' field you can also click on 'Select Design Variable' and select your sweep variable.
     Regards
  • Arjun RP
    I did the steps mentioned by you. I can plot Id vs L. But i cant plot Vth vs L. After simulation if i go to results browser i couldnt see the Vth of the transistor in dc-dc tab. Only in dcOpInfo-info i can see Vth. But that gives only the value of Vth. I doesnt plot Vth vs L as it is operating point simulation. How should i plot Vth vs L from the results browser ?
  • Arjun RP
    I am also getting the following warnings if i use save M0:all and save M0:vth commands in .scs file
    The warnings are consistent with what I guessed might be the problem - I suspect that the model is a subckt and so saving M0:all is not correct - you need to save M0.instNameOfTransistor:all (where instNameOfTransistor is the name of the instance within the subckt model). You'll need to look in the model files to find out the name of the instance.
    Alternatively, use:
     save *:all devtype=bsim4
    which will save everything for all bsim4 instances - so that should do it. Might be simpler than trying to figure out the instance name...
  • Arjun RP
    Hi ,
    I used this command save *:all devtype=bsim4 in my file. Now there is no warning but still i couldnt find the vth in dc-dc of the results browser
    Which simulator version are you using? I just ran this netlist:
    // simple example of a dc sweep of length
    parameters length=1u
    subckt nch (d g s b)
     parameters w=1u l=1u
     M1 (d g s b) nch w=w l=l
     model nch bsim4 type=n
    ends nch
    M0 (d g 0 0) nch w=1u l=length
    VD (d 0) vsource dc=1
    VG (g 0) vsource dc=1
    dc dc param=length start=0.5u stop=10u step=0.5u
    and got the results below in the results browser.
  • Arjun RP
    I am using Virtuoso 6.1.4 (Virtuoso ADE IC6.1.4.500.5) - as seen from Help-->About ADE . I am a student so am not much experienced with running the netlist you have provided. If you can guide me step by step it will be very helpful for me.
    It's the simulator I'm more interested in (so look at the top of the spectre output file to see the subversion).
    I just tried with the same IC version you're using and that worked - see the picture (this was simulated with an MMSIM11.1 simulator version just arbitrarily).
    To run it, put the contents in a file called "vtsweep.scs" and then run "spectre vtsweep.scs". I ran "viva" and then opened vtsweep.raw and plotted the results.
