  3. viva window default size and position
  • Views 16416
david0526
david0526 over 12 years ago
 hello,
 i've been trying to figure out how to set the default size and position of the viva graph and calculator windows (i know you can set the viva window size only via .cdsenv, but no the position).  i tried messing around with the following SKILL snippet which was provided as means of resizing the ADE window, but to no avail (i'm an absolute novice when it comes to SKILL).  if anyone can offer some help on the matter, i'd greatly appreciate it.
procedure(CCSresizeAdeWin(_aseSess)
let((WindowID)
  WindowID = hiGetCurrentWindow()
  when(member(hiGetAppType(WindowID)  '("adexl"  "Artist"))
  hiResizeWindow(WindowID list(120:350 970:1000))  ; <=== Here you will code the values return by hiGetAbsWindowScreenBBox
envSetVal( "asimenv.startup"  "sessInitTrigFunc" 'string "CCSresizeAdeWin")
  • dontpanic
    dontpanic over 12 years ago
     Hi! I am having the very same problem,  hiResizeWindow() does not seem to work with VIVA windows. Does somebody have a workaround for this???
    Thanks in advance,
     Jorge.
  • dontpanic
     BTW, I'm trying to make it work using something like this:
    hiResizeWindow(awvGetCurrentWindow() list(0:70 1912:1050))
    hiFlush()
    The command returns "t", but the window does not change at all! :\
