  3. Multiple netlists in single Spectre input file
  • Views 15453
anla
anla over 12 years ago
Hi.
Is is possible to have multiple netlists in a single Spectre input file?
For instance, I can run something like
        * single resistor circuit
        .param vd=1 r1=1k dummy=0
        r1 1 0 r=r1
        vdd 1 0 dc=vd
        .dc dummy 0 1 1
        .measure dc i1 find i(vdd) at=1
        .end
        * voltage divider circuit
        .param vd=5 io=1m r1=1k r2=2k dummy=0
        r1 1 2 r=r1
        r2 2 0 r=r2
        vdd 1 0 dc=vd
        iout 2 0 dc=io
        .dc dummy 0 1 1
        .measure dc vout find v(2) at=1
        .end
through SPICE. Two separate simulations are performed sequentially.
Can I do something similar with Spectre? Running the above-mentioned file through Spectre with "spectre +spice" just simulates the single resistor circuit, but does not analyze the voltage divider. Is there a chance to tell Spectre that there are two netlists in on input file when using +spice command line option?
Alternatively, the netlists can be transformed to Spectre:
        // single resistor circuit
        parameters vd=1 r1=1k
        r1 (1 0) resistor r=r1
        v1 (1 0) vsource dc=vd
        dc1 dc
        <<HOW TO SEPARATE THESE SECTIONS??>>
        // voltage divider circuit
        parameters vd=5 io=1m r1=1k r2=2k
        r1 (1 2) resistor r=r1
        r2 (2 0) resistor r=r2
        vdd (1 0) vsource dc=vd
        iout (2 0) isource dc=io
        dc1 dc
Is there a suitable separator to achieve that Spectre runs to separate simulations?
Thank you.
André
    André,
    I think the answer is no - potentially you could use a bunch of altergroups and alter statements between them, but it would be messy and I see no advantage over just running with two separate netlists. If you really want to put everything in a single file, you could do:
            #ifdef SINGLERES
            dc1 dc
            #endif
            #ifdef VOLTAGEDIV
            dc1 dc
            #endif
    and then you could do (in csh):
    foreach circuit (SINGLERES VOLTAGEDIV)
      spectre -raw $circuit.raw -D$circuit combinedfile.scs
    end
    That would give you two sets of results from a single input file. Spectre supports this kind of use of cpp (C pre-processor) directives.
