  3. How to close a netlist in Ocean
  • Views 15113
lchen
lchen over 12 years ago
I’m running an ocean script that runs multiple PVT corners in a nested foreach loop (see sample below). It runs all the PVT corners in parallel using LSF.
The problem I’m having is that at each corner, the run generates a netlist. With post-layout extraction, the netlist could be ~100M, and soon enough, Ocean runs out of memory.
I want to ask if there’s a simple command I could use to close the netlist before proceeding to the next iteration of the loop. That way Ocean doesn’t run out of memory just submitting jobs to the LSF queue.
Pseudo-code:
foreach(corner cornerlist
foreach(vdd vddlist
foreach(temp temlist
run(?jobName job ?drmsCmd bsub_cmd)
); end foreach templist
); end foreach vddlist
); end foreach model
  • Quek
    Quek over 11 years ago
    Hi Ichen
    Would you please try adding ocnResetResults() in the innermost foreach loop to see if it helps?
                ocnResetResults()
    Best regards
    Quek
  • lchen
    lchen over 11 years ago
    Hi Quek,
     Thanks for the suggestion. Your recommendation worked. ocnResetResults() reduced the memory footprint used by Ocean by 6x.
    Best regards,
