  3. Problem with Assura license
  • Views 16521
03123308555
03123308555 over 11 years ago
 After successful DRC and LVS verification RCX (C extraxtion) fails with the following error:
            Assura (tm) Physical Verification Version av3.2:Production:dfII6.1.3:IC6.1.3.500.7
            Release 3.2_USR2_HF11
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av3.2:Production:dfII6.1.3:IC6.1.3.500.7 06/29/2009 05:57 (sjlin84) $
sub-version 3.2_USR2_HF11, integ signature 2009-06-29-0444
run on rose.eecg from /autofs/fs1.ece/fs1.vrg.CMC/tools/cadence.2000a/ASSURA-613.03.20.022.linux/tools.lnx86/assura/bin/32bit/assura on Fri Aug 22 11:34:54 2014
Checking out 1 license for Assura_RCX 3.10
ERROR (LMF-02018): License call failed for feature Assura_RCX, version 3.100 and quantity 1. The license server search path is defined as 7055@u10e.vrg.utoronto.ca:6055@u10e.vrg.utoronto.ca:/CMC/tools/licenses/cds.license:/CMC/tools/licenses/amslmd_v400.license. The FLEXnet error message is as follows,
    FLEXnet ERROR(-18, 0, 0): License server system does not support this feature.
Run 'lic_error LMF-02018' for more information.
ERROR (LMF-02018): License call failed for feature Virtuoso_QRC_Extraction_L, version 3.100 and quantity 1. The license server search path is defined as 7055@u10e.vrg.utoronto.ca:6055@u10e.vrg.utoronto.ca:/CMC/tools/licenses/cds.license:/CMC/tools/licenses/amslmd_v400.license. The FLEXnet error message is as follows,
ERROR (LMF-02018): License call failed for feature Encounter_QRC_Extraction_L, version 3.100 and quantity 1. The license server search path is defined as 7055@u10e.vrg.utoronto.ca:6055@u10e.vrg.utoronto.ca:/CMC/tools/licenses/cds.license:/CMC/tools/licenses/amslmd_v400.license. The FLEXnet error message is as follows,
Starting /CMC/tools/cadence/ASSURA-613.03.20.022.linux/tools/assura/bin/rcxToDfII /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/ASSURA_LVS/rail_comparator/rcx.rail_comparator.rsf -t -cdslib /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/cds.lib -libdefs /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/lib.defs
@(#)$CDS: rcxToDfII version av3.2:Production:dfII6.1.3:IC6.1.3.500.7 06/29/2009 06:01 (sjlin84) $
run on rose.eecg from /autofs/fs1.ece/fs1.vrg.CMC/tools/cadence.2000a/ASSURA-613.03.20.022.linux/tools.lnx86/assura/bin/32bit/rcxToDfII on Fri Aug 22 11:34:58 2014
Loading all available p-cell functions
AMS_DB set to cds
No mx check
No mx check
ROD pcell code loaded
Finished /CMC/tools/cadence/ASSURA-613.03.20.022.linux/tools/assura/bin/rcxToDfII
Starting /CMC/tools/cadence/ASSURA-613.03.20.022.linux/tools/assura/bin/avRCXxref /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/ASSURA_LVS/rail_comparator/rcx.rail_comparator.rsf
@(#)$CDS: avRCXxref version av3.2:Production:dfII6.1.3:IC6.1.3.500.7 06/29/2009 05:57 (sjlin84) $
run on rose.eecg at Fri Aug 22 11:34:59 2014
Reading rsf
Finished /CMC/tools/cadence/ASSURA-613.03.20.022.linux/tools/assura/bin/avRCXxref
Constructing the RCX run script
*** ASSURA capgen VERSION 3.2 Red Hat Linux release 7.2 (Enigma) - (04/30/2009-14:21)  ***
*   (c) Copyright 2014, Cadence Design Systems, Inc.     *
* All rights reserved.     *
*  This software is the confidential and proprietary information of  *
*  Cadence Design Systems, Inc. and may not be copied or reproduced  *
*   in whole or in part onto any medium without Cadence's express    *
*    prior written consent. Unpublished rights reserved under all    *
* copyright laws of the United States.     *
*     Cadence Design Systems, Inc.     *
* 555 River Oaks Parkway     *
*  San Jose, CA 95134     *
capgen Capgen results will be written to directory: /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/ASSURA_LVS/rail_comparator/rail_comparator
*ERROR* at "capgen": -res_blocking mask layer 'rblock_poly1' not defined in LVS file
quitting.
Forking:  /CMC/tools/cadence/ASSURA-613.03.20.022.linux/tools/assura/bin/32bit/capgen -substrate_stamping_off -techdir /autofs/fs1.ece/fs1.vrg.CMC/kits/amsp35.v4.00/assura/h35b4/h35b4d3/RCX-typical -lvs /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/ASSURA_LVS/rail_comparator/rail_comparator.xcn -p2lvs /autofs/fs1.ece/fs1.vrg.CMC/kits/amsp35.v4.00/assura/h35b4/h35b4d3/RCX-typical/p2lvsfile -length_units meters -cap_unit 1.0 -selected_paths_proper -p poly1,capgen_gate,diffusion -no_cap_correction -cap_ground_layer net_psub -dsub net_pwell,net_nwell,net_psub -lexclude poly2,poly1 -blocking cblock_met3_poly1,met3,met2,met1,poly2,poly1 -blocking cblock_met3_psub,met3,met2,met1,poly2,poly1,diffusion,fox -blocking cblock_met2cap_met2,met2cap,met2 -blocking cblock_met1_poly1,met1,poly1 -blocking cblock_poly2_poly1,poly2,poly1 -blocking cblock_poly1_psub,poly1,diffusion,fox -res_blocking rblock_poly1,net_poly1 -res_blocking rblock_poly2,net_poly2 -res_blocking rblock_met1,net_met1 -res_blocking rblock_met2,net_met2 -res_blocking rblock_met3,net_met3 -res_blocking rblock_met4,net_met4 -sw3d /autofs/fs1.ece/fs1.eecg.roman/yuhu/AMSP35HV/ASSURA_LVS/rail_comparator/rail_comparator
*WARNING* Bad return status from RCX script generator. 0x100
How to solve it? Thanks!
  • Quek
    Quek over 11 years ago
    Hi 03123308555
    RCX has already been retired a number of years ago and has already been replaced by Quantus QRC. Quantus is available in EXT package. Assura-Quantus flow should use Assura LVS (from ASSURA package) and Quantus (from EXT package).
    You can resolve your problem as follows:
    a. Check if you have Quantus licenses.
    terminal>lmstat -a -c $LM_LICENSE_FILE | grep QRC
    OR
    terminal>lmstat -a -c $CDS_LIC_FILE | grep QRC
    b. If Quantus licenses are available, please install EXT package from http://downloads.cadence.com and add the following lines to your .cshrc file:
    setenv QRC_HOME /your-path/EXT14.1
    set qrcPath=($QRC_HOME/bin)
    set path=($qrcPath $path)
    c. If Quantus licenses are not available, please kindly contact your local Cadence support for help on purchasing the licenses.
    Best regards
    Quek
