  3. how to determine if rod is choppable?
  • Replies 7
  • Views 17164
archive over 19 years ago
I am trying to write some SKILL code to analyze a rod obj and generate the necessary SKILL code to regenerate the same object.  However, I cannot find any prop in the rodObj, it's dbId, or any of the subShapes to report if the master or any subparts are choppable?
How can I determine this?
Suggestions on a better way?  :-)
Thanks!
Originally posted in cdnusers.org by m27315
    I think there is now way, at least not straight forward one,
    except the graphical edit properties form.
    Bernd
    Originally posted in cdnusers.org by bernd.fischer
    Posted By bernd.fischer on 11/16/2006 12:58 AM
    Bernd
    Maybe this is what you meant by "not straight forward", but I did a dbWriteSkill and noticed that the "missing" ROD object properties are "grouped" together and associated with the rod object.  However, I cannot figure out how to navigate from the rod object to these "user-level" group properties.  Is there some way to find all the groups in a cellView or that are associated with an object?  Or, am I not understanding this correctly?
    Here's some of the interesting SKILL code from dbWriteSkill, as an example of the groups I am trying to find after cellView creation:
    dbD_0xd357c2c = dbOpenCellViewByType("myLibName" "myCellName" "layout" "maskLayout"
                                         "w")
    dbD_0xd3eb018 = dbCreateGroup(dbD_0xd357c2c "masterPath" list("collection"
                                  "unordered" "nonUniqueName" "deleteNever"))
    dbD_0xd3eaf54 = dbCreateGroup(dbD_0xd357c2c "chopRec" list("collection"
    dbD_0xd3eb000 = dbCreateProp(dbD_0xd3eaf54 "nPoints" "int" 2)
    dbD_0xd3eaf80 = dbCreateProp(dbD_0xd3eaf54 "segPoints" "ILList" '((64700 0) (64700 7000)))
    dbD_0xd3ead54 = dbCreateGroup(dbD_0xd357c2c "path34" list("set" "unordered"
                                  "uniqueName" "deleteNever"))
    dbD_0xd3eaf3c = dbCreateProp(dbD_0xd3ead54 "rodMasterChopStatus" "boolean" t)
    dbD_0xd3ead94 = dbCreateHierProp(dbD_0xd3ead54 "masterConnProps")
    dbD_0xd3eaefc = dbCreateProp(dbD_0xd3ead94 "handleOffsetPt" "ILList" '(0 0))
    dbD_0xd3eaee4 = dbCreateProp(dbD_0xd3ead94 "handleName" "string" "centerCenter")
    dbD_0xd3eaecc = dbCreateProp(dbD_0xd3ead94 "orient" "int" 1)
    dbD_0xd3eaeb4 = dbCreateProp(dbD_0xd3ead94 "drafting" "boolean" t)
    dbD_0xd3eae9c = dbCreateProp(dbD_0xd3ead94 "fontStyle" "int" 6)
    dbD_0xd3eae84 = dbCreateProp(dbD_0xd3ead94 "justify" "int" 5)
    dbD_0xd3eae6c = dbCreateProp(dbD_0xd3ead94 "pinLabelPurpose" "int" 242)
    dbD_0xd3eae54 = dbCreateProp(dbD_0xd3ead94 "pinLabelLayer" "int" 230)
    dbD_0xd3eae3c = dbCreateProp(dbD_0xd3ead94 "height" "int" 3280)
    dbD_0xd3eae24 = dbCreateProp(dbD_0xd3ead94 "pinLabel" "boolean" t)
    dbD_0xd3eae0c = dbCreateProp(dbD_0xd3ead94 "accessDir" "int" 3)
    dbD_0xd3eadf4 = dbCreateProp(dbD_0xd3ead94 "isPin" "boolean" t)
    dbD_0xd3eaddc = dbCreateProp(dbD_0xd3ead94 "termDir" "int" 3)
    dbD_0xd3eadc4 = dbCreateProp(dbD_0xd3ead94 "termName" "string" "G3")
    dbD_0xd3eadac = dbCreateProp(dbD_0xd3ead94 "netName" "string" "G3")
    dbD_0xd3ead7c = dbCreateProp(dbD_0xd3ead54 "MPPVersion" "int" 2)
    Any thoughts?
    I couldn't find a attribute called chopabel or similar
    at
    rodGetObj( dbId )~>??
    or
    rodGetObj( dbId )~>subShapes~>??
    And that's the place where I would expect it, if
    existing. That's what I meant with not straight
    forward.
    Hopefully somebody at Cadence monitors this thread and
    can give a somehow more detailed answer.
    Bernd
  • Adrian Nistor
    Adrian Nistor over 11 years ago
    Hi, After ... ~8 years+ I came back with the same question:
    How can I access (read / change) the choppable property of the master path ? With the edit properties form it works. Where is the Edit Properties Form taking the information from?
    Thank you,
    BR,
    Adrian
    Adrian,
    There is no SKILL API currently for this. CCR 1049177 was filed for this, and has been implemented in the upcoming IC617 and ICADV12.2 releases, where there will be:
    rodIsMasterChoppable(rodId)
    rodSetMasterChoppable(rodId t/nil)
  • Sorin JIANU
    Sorin JIANU over 11 years ago
    MPP – having subparts chopped in many places.
    How can I remove one chop? Using SKILL code.
    rodGetObj(css())~>chopHoles
    ((((-92600 -9650)
    (-90050 -9650)
    (-90050 -4325)
    (-86825 -4325)
    ((-78900 -4325)
    (-70700 -4325)
    ((-78900 -4325)
    (-70700 -4325)
    BR
    Sorin JIANU
    I don't believe there's an API to remove chop holes. You'd need to contact customer support to request this.
