  3. Setting up used defined graph properties
  • Views 23515
Darshak
Darshak over 12 years ago
 Dear Team,
I am facing too much problem for setting up graph properites again and again like font size, background color, marker fonts etc.
 Can you please guide me how can i permenantly configure my default graph setting so that it will not change for every graph.
I am using cadence 6.1.5
 Please answers my doubts. I am posting many post but not getting answer. Otherwise provide your customer care email. Why cadence is not that much userfriendly.
Darshak
  • Tom Volden
    Tom Volden over 12 years ago
    There are .cdsenv variables that can be used to load your desired defaults.  These are all defined in Appendix A of the ViVA User Guide (http://support.cadence.com/wps/PA_DocumentViewer/pubs/vivaxlug/vivaxlug6.1.6/appA.html#1052258).
    For the specific items that you mentioned, you can use the following in your .cdsenv file to set the background color to white:
    viva.rectGraph foreground string "white"
    or the equivalent command in your .cdsinit file:
    envSetVal("viva.rectGraph" "foreground" 'string "white")
    Similarly there are a number of .cdsenv variables that allow you to customize the various fonts that are used in the waveform window:
    viva.graph titleFont string "Default,10,-1,5,55,0,0,0,0,0"
    viva.traceLegend font string ""
    viva.traceLegend printSaveImageFont string ""
    viva.axis font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.horizMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.referenceLineMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.vertMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.pointMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.refPointMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.specMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.interceptMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.circleMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.multiDeltaMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.transEdgeMarker font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.graphLabel font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.polarGrid font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.smithGrid font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.regionBookmark font string "Default,10,-1,5,50,0,0,0,0,0"
    viva.xrangeBookmark font string "Default,10,-1,5,50,0,0,0,0,0"
    For these variables, the font string is
    <Font family>, <Point size>, <Pixel size>, <Style hint>, <Weight>, <Style>, <Underline>, <Strikeout>, <Fixed pitch>, <Raw mode>
    so you can increase the size of the font by increasing the second item in the string.
  • Darshak
     Thank you for your reply. Can you help me for one more thing.
     I was using cadence 514 and just now switch to cadence615. I have included RFlib from "  ../ic5p41/tools/dfII/samples/artist/rfLib "
    But i can not able to find for cadence 6. Can you please provide me path to include RFlib.
    Darshak
    Darshak,
    rfLib is in exactly the same place under the IC61X installation.
