  3. converting bus pin to non bus in Layout L
  • Views 15447
FlinxSL
FlinxSL over 11 years ago
I am having trouble converting a bus pin to a non-bus pin using Layout L.  I managed to reproduce the error I am seeing in a junk layout following these steps:
  1. draw a pin named junk_pin<0> and give it a label
  2. delete the pin
  3. draw a pin named junk_pin
It then gives the error that it cannot create a net with name junk_pin because a bus net with base name 'junk_pin' already exists.  I don't know how to delete this net and would appreciate help.
my cadence version is 6.1.6-64b.500.7
  • theopaone
    theopaone over 11 years ago
    I'm on holiday so do not have access to Virtuoso to try this.
    Use dbFindBusNetDefByName to find the net ID and delete it:
    netId = dbFindBusNetDefByName(geGetEditCellView() "junk_pin" )
    dbDeleteObject( netId )
    Or:
    dbDeleteObject(dbFindNetByName(geGetEditCellView() "junk_pin<0>"))
    I sort of think that VLS should clean up stranded nets and terminals - I thought it used to. So I would contact customer support to try to ensure that it doesn't leave terminals/nets with no pins/figures respectively.
