  3. Diva drcAntenna cumulative check
  • Subscribers 133
  • Views 15201
archive over 19 years ago
Hi all,
Does anyone know, how correctly write rules for cumulative check?
I've followed by divaref.pdf manual 339p. example:
ratio = if(diode 0 antenna / if(gate gate 1))
ratio = cumulative + byShape(ratio gate)
error(ratio > antenna_limit good msg ratio)
, but have got following errors:
 error:  drcAntenna error expression does not allow both net and shape based values.
 error:  error clause ratio must be net based to match the expression.
It seems, that error clause want, that ratio expression will be net based.
But by example "ratio = cumulative + byShape(ratio gate)", it is shape based.
Where is a point?
Thanks, Giedrius
Originally posted in cdnusers.org by giedrius
    I tried to create a rule deck based on your fragment, but I do not get the error message. Can you post the entire drcAntenna rule that has the error, the drcAntenna which outputs cumulative, and the definition of any values like antenna_limit? You may have a bug, an error in the deck, or the ever popular older build of the software ;)
    Originally posted in cdnusers.org by ekalenda
    I've already fixed that problem. It was my dumb mistake.
    My bad case was: "error(ratio > antenna_limit gate msg ratio)".
    Should be: "error(ratio > antenna_limit good msg ratio)".
    Sorry, Giedrius
