  3. How to set / overwrite instance inherited netset property...
  • Views 17037
How to set / overwrite instance inherited netset property in layout view?
sl3j
sl3j over 11 years ago
I am trying something like this
dbCreateProp(myInst "vdd"  "netSet"    vdd1)
It does not seem to work, the connectivity in Layout XL does not show any change!
The signal vdd1 already alread exists in the layout.
 Any way to change signal mapping of instance terminals?
    In general inherited connections in layout are a slightly different concept, because you always have physical connectivity - you want to connect up based on wires connected to pins. I don't believe adding a netSet on an instance will override the connectivity because presumably any nets within the instance would have a pin with a netExpr on (that you're attempting to override) but the instance would have instTerms which are connected to a specific net at this level. An instTerm connected to a net will always override whatever the netExpr said.
    Not sure if that was very clear - it's hard to describe without an example. So maybe talking this through with customer support would make sense?
  • sl3j
     It should help thank you. I will try in that sense and share my findings.
    By the way, I am reading your comments and answers since 2 to 3 years  and always found them relevant to a point I never got to send a question. So keep going I am sure many readers share my compliment.
    -Sami
  • sl3j
     As promessed for sharing the findings,
    here is the solution I propose based on your hints.  It works at the cellview level.
    I have not yet tried if we should map both "gnd" and "gnd!" terminals to enable inherited connection propagation down into the hierarchy,
    thanks
    -Sami
    procedure(SLMapInstTerm(cv InstName TermName NetName)
    let( (myInst myInstTerm myNet )
    if( myInst=dbGetInstanceByName(cv InstName) then
    ; creating new net or getting it if existing
    if( (myNet = dbFindNetByName(mycv NetName))  then
         else
        myNet = dbCreateNet(mycv NetName)
        printf(" --I-- New Net %s created \n" myNet~>name)
    ; Mapping the terminal by name to the new net
    foreach(myInstTerm myInst~>instTerms
            if(myInstTerm~>name == TermName then
                myInstTerm~>net = myNet
                printf(" --I-- Connection remapped   %s :  term %s   -> %s\n" myInst~>name TermName  myNet~>name))
    else
        printf(" --W-- Instance Not found : %s \n" myInstName)
    ; quick test
    mydb=hiGetCurrentWindow()
    mycv=mydb~>cellView
    SLMapInstTerm(mycv "I1" "gnd!" "GND1")
    SLMapInstTerm(mycv "I2" "gnd!" "GND1")
