  3. Co-ordinates of source & drain terminals
  • Views 1589
BALBOA
BALBOA over 11 years ago
 How do I find out the co-ordinates of source & drain terminal of an instance using skill??
  • theopaone
    theopaone over 11 years ago
     The actual connection elements are the figures which are designated pins on the terminals in the master.
    instId~>master~>terminals~>pins~>figs
    termIds = setof( term instId~>master~>terminals member( term~>name list( sourceTermName drainTermName ) )
    pinFigs = termIds~>pins~>figs ; This is a list of lists
    The figs are the objects in the master so if you want the coordinates of the objects, you have to transform their internal (master) coordinates by the instance transform -> dbTransformPoint( figPoint instId~>transform)
     Ted
