  3. Changing config view within a single ADEXL test
  • Views 20974
Ivars
Ivars over 11 years ago
 I often use config views (set up using the Heirarchy Editor) to switch between schematic and extracted views of a circuit block during simulations. I would like to run a single ADEXL test which compares a schematic view with the extracted view.
Ideally I'd like to specify which config view to use in a global variable and then sweep that variable during the test. The problem is that the config view used by a ADEXL test is set under the "Design ..." menu, something that can't be parameterized.
Is it possible to set up an ADEXL test so that the config view to be used can be changed via a design variable?
 What I want to avoid is the need to create two ADEXL tests. One for the schematic view and one for the extracted view. The issue I have with this approach is that it is difficult to keep the two tests identical. Any changes in one test has to be copied to the other.
The two test approach would be a viable solution if ADXEL allowed one test to be a "child" of another with specific overrides (instead of a full and independent copy).
 Any advice would be greatly appreciated. Thanks.
 Ivars
  • Tom Volden
    Tom Volden over 11 years ago
    Hi Ivars,
    This is not currently possible for config view in ADE XL. There is an existing CCR requesting this ability (1162698).
    For views which are netlisted using switch/stop views it is possible to include a global variable in the switch view list using something like VAR("myView") and vary the myView global variable in a sweep or corners run to change the view that will be used for netlisting in each corner/sweep point.
    TOM
  • Ivars
     Tom,
     Thanks for the suggestion to use stop views. I hadn't thought of that approach.
    With careful naming of the views I can probably use this approach to implement my goal for cases requiring only a few blocks to be swapped.
     I'll give it a try.
    Ivars
  • Qcar
    Qcar over 11 years ago
    Hi, Is it feasible to use config views in ADE XL in virtuoso version ICADV12.2-64b 01/27/2015? Qcar
  • Tom Volden
    Yes, config views are supported in ADE XL.
    Additionally as of 616 ISR 11, the ability to sweep views a list of views is available.  This is similar to what the original poster of this thread requested.  See the Parameterizing Cellviews Defined in the Config View section of the ADE XL User Guide (http://support.cadence.com/wps/PA_DocumentViewer/pubs/adexl/adexl6.1.6/adexlParameterization.html#configSweeps)
    TOM
