  3. 'nmos4' is an undefined primitive device
  • Views 11553
ajmedina
ajmedina over 11 years ago
I am trying to use the nmos4 instance which I found in analogLib but I get the following error:  'nmos4' is an undefined primitive device.  I tried using the following library file which I created:
simulator lang=spectre
library nmos
section ss
model nmosajm nmos4 tnom=27 TOX=4.1E-9 XJ=1E-7
endsection ss
endlibrary nmos
I also tried using the following model file:
.model nmosajm nmos4 tnom=27 TOX=4.1E-9 XJ=1E-7
I realize I'm missing a ton of parameters but I figure I should get past the  'nmos4' is an undefined primitive device error before I move on.
Hope someone can help.
Andy
  • Tom Volden
    Tom Volden over 11 years ago
    Hi Andy,
    nmos4 is a symbol instance in analogLib, but it needs to be mapped to one of the valid device types in spectre.  In the case above it looks like you would be setting the model name to nmosajm when you instantiate the device in the schematic.  That's fine, you just need to make sure the definition of that model is correct.   You should decide which model you want to use and then use that in your model statement rather than nmos4.  Some typical choices for fictional processes like this are bsim3v3 or bsim4, but there are dozens of other choices as well.  You can get a list of the available model types by entering "spectre -h" and looking for the list in the section that starts with "Available components".  You can then get additional information about the model parameters by entering "spectre -h <component type>", for example, "spectre -h bsim3v3".  In your case, the model definition might look like:
    model nmosajm bsim3v3 type=n tnom=27 tox=4.1e-9 xj-1e-7
    TOM
  • ajmedina
    Thanks Tom, the simulation ran without error after adding a period before "model":
     .model nmosajm bsim3v3 type=n  tnom=27 tox=4.19n
     Is that proper syntax when using Spectre?
    Best
    Andy
    If the model is in a file with a ".scs" suffix, then it should be in spectre syntax. If it has any other suffix, it's assumed to be in SPICE syntax. Spectre syntax doesn't have the leading dot, whereas SPICE does.
    You can explicitly set the language by adding:
    or:
    simulator lang=spice
    directives to change language mode. Anything after the directive in the same file will use the last language directive.
  • ajmedina
    Thanks!
