  3. Magnetic Tunneling Junction (MTJ)- HSpice file simulation...
  • Subscribers 136
  • Views 6487
Magnetic Tunneling Junction (MTJ)- HSpice file simulation in ADE -Cadecne Virtuoso
AkashUB
AkashUB over 11 years ago
    I am working on modeling of STT-MTJ using Cadecne Virtuoso.  I am trying to simulate model ' MTJT.inc '   (  Ref : - Jon Harm, Farbod Ebrahimi- Univertsity of Minnesota ) using Cadence Virtuoso Spectre.
    I have following doubt    :-
       MTJ as a device, how do I instantiate a this H-spice sub-circuit file physically on schematic and simulate with Spectre in ADE-L? In schematic should I need to place all internal electrical component that explained in subcirciut?  How to change CDF parameters for this file?
I would be obliged for your possible guidance. I am sorry but I am new in macro mdeling and sub circuit simulation. Thank you.
For reference MTJT.Inc  file :-
** MTJT macro-model
** Authors:
**	Jon Harms		(harms074@umn.edu)
**	Farbod Ebrahimi	(ebrah008@umn.edu)
** Latest Update:
**	2009 08 13
** Declaration of Sub-circuit
.SUBCKT MTJT n+ n-
.PRINT R(gMTJ)
** User Parameter Defaults
.PARAM
+	ICAP=346u
+	ICP=346u
+	RAP=1008
+	RP=288
+	RVFIT=.5
+	THSBT=22
+	IC=-1
+	TTP=7n
+	PCAP=.6f
+	ITPP='ICP*(1-THSBT*log(TTP/1n))'
+	ITPAP='ICAP*(1-THSBT*log(TTP/1n))'
** MTJ Electrode Connections
*~Voltage Controlled Resistor
gMTJ 	n+	nVCR1	VCR	nVCtrl	0	1e3
*~Parasitic Capacitance
cPara	n+	nVCR1	'PCAP'
*~Current Sampling
vISample	n-	nVCR1	DC=0
*~Binary Current Sensors
eISensBin1	nINeg 0	VOL='EXP(5*I(vISample)/ICP)-1' MIN=0 MAX=1
eISensBin2	nIPos 0	VOL='EXP(5*I(vISample)/-ICAP)-1' MIN=0 MAX=1
** Decision Circuit
*~Current mirrors
gMirror1	n51	n50	CUR='1/(EXP(THSBT*(1+I(vISample)/-ICAP))+TTP*1e5*(-ITPAP/I(vISample))^2)' MAX=10
gMirror2	n50	n51	CUR='1/(EXP(THSBT*(1+I(vISample)/ICP))+TTP*1e5*(ITPP/I(vISample))^2)' MAX=10
*~Decision capacitors
cDec1	n50	0 1n IC=0
cDec2	n51	0 1n IC=0
*~Voltage limiters
rlim1	n50	n60	.01
elim1	n60	0	n50	0	1	MIN=0 MAX=1.01
rlim2	n51	n61	.01
elim2	n61	0	n51	0	1	MIN=0 MAX=1.01
rshunt1 n50 0 10g
rshunt2 n51 0 10g
*~Current controlled 2:1 MUX
eMux3 nVDec	0	VOL='v(n50)*v(nINeg)-v(n51)*v(nIPos)'
** Bi-stable Multivibrator
*~Amplifier w/clipping
eBiStable	nBiStable	0	VCVS	nFeedback	0	10000	MAX=10V		MIN=-10V
*~Positive Feedback
rFB1	nVDec	nFeedback	1e3
rFB2	nFeedback	nBiStable	10e3
*~Initial Conditions
cIC1	nFeedback	0	1f	IC='(IC<0)?-1V:1V'
cIC2	nBiStable	0	1f	IC='(IC<0)?-10V:10V'
*~Biasing and offset
eVTMR	nVTMR	0	VCVS	nBistable	0	1	MIN='RP/1e3' MAX='RAP/1e3'
** Curve Fitting Circuit
*~Curve fitting amplifiers
eRVFit	nRVFit 	0	VOL='v(nVTMR)*(EXP((PWR(ABS(v(n+)-v(n-)),2)/(-2*RVFIT))))'
*Feedback filter (avoids oscillation)
rShunt3 	nRVFit nVCtrl 1k
cSRL2 	nVCtrl 0 6f
.ends MTJT
  • Quek
    Quek over 11 years ago
    Hi AkashUB
    Here is how you can do it:
    a. Rename n+ and n- to nPlus and nMinus
    .SUBCKT MTJT n+ n-
    b. Create a cell "MTJT" that has a symbol with pins nPlus and nMinus
    c. Go to the CDF of the cell and go to simInfo section. Set subcircuit name to "MTJT" and ensure that the termOrder is "nPlus nMinus".
    d. Copy symbol view as "hspiceD" view
    e. Open ADE, switch to hspiceD simulator and add the subckt file as one of the model files.
    f. Run simulation
    Best regards
    Quek
  • AkashUB
    Hi Quek,  Thanks a lot for great guidance. Please could you elaborate little more about 'Copy symbol view as "hspiceD" view'?
    Thank you.
  • Quek
    Hi AkashUB
    Here are the details:
    a. In library manger, select the "symbol" view which you had created
    b. Right mouse click and select "Copy" from the right mouse menu
    c. Enter "hspiceD" as the name for the new view
    Best regards
    Quek
  • AkashUB
    Hi Quek,
        Really thanks for your qiuck and helpful response. I follow all your instructions, sorry but I am getting this error :
    " ERROR (OSSHNL-108): The property, 'connectivityLastUpdated', specified on library 'MTJT_15thSept', cell 'MTJT',
    view 'hspiceD', does not have an integer value. Re-extract the design (File->Check
    and Save menu option) to correct this error.
    End netlisting Sep 17 11:07:14 2014
    ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
    ...unsuccessful. "
        Could you please help me in this. I have attched '.doc'-file  along with this post for your reference. Please find attachment.
    MTJT_Error_Cadence.doc
  • Quek
    Hi AkashUB
    Would you please do the following?
    a. Open up "symbol" view of the MTJT_15thSept cell in library manager
    b. Execute "File->Check and Save"
    c. Repeat steps "a" and "b" for "hspiceD" view
    Best regards
    Quek
  • Surya Kiran
    Surya Kiran over 11 years ago
     Are you working on hspiceD simulator?
    The model works well in spectre simulator.
    Surya
