  3. Stretch all shapes by certain factor?
  • Views 15217
egolowen
egolowen over 11 years ago
I was wondering if there was any way of being able to stretch all shapes in a layout design by a certain factor? For example, if my CPP is changing from 100 to 90, is there any way to easily stretch everything by a factor of 100/90?
Elizabeth
PS. Apologies if I've posted this in the wrong section.
    Elizabeth,
    So you're asking about scaling rather than stretching. For that, your best bet is to use the command-line "XScale" utility. Run with no arguments and it will tell you how to use it - also search for it in cdnshelp for more details.
  • skillUser
    skillUser over 11 years ago
    Hi Elizabeth,
    Here's a link to the documentation for IC616 on Support.Cadence.com.
    regards,
    Lawrence.
