  3. Failed to open shared object file.
  • Views 15564
Xegotronix
Xegotronix over 11 years ago
We have ICFB5.1.41 installed on RHEL6.5.
ASSURA version is 4.1_USR4_HF6.
We get the error shown in the attached image and the Assura menu does not show up in Virtuoso Layout.
Any ideas on how to tackle this issue?
The GCC version we have installed is  4.4.7.
I doubt if the 4.4.7 is backward compatible with the 4.2.0 that the tool is looking for.
Here is our .cshrc:
 setenv LM_LICENSE_FILE 5280@cadence02
 setenv CDS_Netlisting_Mode Analog
 setenv PSF_WRITE_CHUNK_MODE_ON true
 setenv QRC_HOME /opt/cadence/installs/EXT132
 setenv CDSHOME /opt/cadence/installs/IC5141
 setenv MMSIMHOME /opt/cadence/installs/MMSIMM131
 #setenv LD_ASSUME_KERNEL 2.4.1
 setenv ASSURAHOME /opt/cadence/installs/ASSURA41
 setenv PATH /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:
${MMSIMHOME}/tools.lnx86/bin:${MMSIMHOME}/tools.lnx86/dfII/bin:${CDSHOME}/tools.lnx86/bin:
${CDSHOME}/tools.lnx86/dfII/bin:${CDSHOME}/tools.lnx86/plot/bin:${QRC_HOME}/bin:
${ASSURAHOME}/tools.lnx86/assura/bin
 setenv LD_LIBRARY_PATH /usr/lib:${CDSHOME}/tools/lib:${CDSHOME}/tools/systemc/gcc/install/lib:
${MMSIMHOME}/tools/dfII/lib:${MMSIMHOME}/tools/lib:${MMSIMHOME}/tools/ultrasim/lib:
${CDSHOME}/tools/verilog/lib
 setenv LANG C
 rehash
  • oldmouldy
    oldmouldy over 11 years ago
    You may not be able to resolve this issue since RHEL 6 is not a supported platform for Assura 4.1, check the Supported Platform Matrix on the Cadence Support site:
    Product: ASSURA 4.1
    Begin Support: 6/26/2009
    End Support: 12/31/2015
    Supported Platforms: 32-bit: RHEL 3, RHEL 4; 64-bit: RHEL 3, RHEL 4, RHEL 5, SLES 9,  SLES 10
    You probably need to contact Cadence Support and discuss your options.
    EDIT: Checking the downloads site for available items for Assura 4.1 , there are some Update images for Assura 4.1 for RHEL 6 support but these appear to be for IC6x, rather than IC5x, 04.14.001 is the latest image.
