  3. controlling analog stop time via command line
  • Subscribers 133
  • Views 15294
freitas
freitas over 11 years ago
All,
I need to override the simulation time which is specified in the analog control file via command line.
Ideally using -spectre_args "???"
Any ideas if this is possible?
    One way would be to make the analog control file have:
    tran tran stop=MYSTOP
    and then from the command line use:
    -spectre_args -DMYSTOP=3u
    etc.
    You could also potentially use a Tcl file using -input, but it would get a bit complicated if you do that. You'd have to do:
    run
    analog-stop 4us
    run
    if you wanted to extend it beyond your default value in the analog control file, and:
    run 1us
    if you wanted it shorter than the default.
    So probably the -D approach is simpler.
  • freitas
    It works like a charm!
    Thanks a lot!
