  3. Check for Monte Carlo simulation in Spectre subcircuit?
  • Views 16148
anla
anla over 11 years ago
Hi!
Is there a chance to make Spectre check whether it runs a Monte Carlo (MC) simulation from within a subcircuit?
Consider the following example:
subckt my_suckt <pins>
  if( MC run ) {
    <<generate random parameter a>>
  } else {
    parameters a=4
  // circuitry using parameter a
ends
There is a parameter a in a subcircuit. In a nominal simulation, its nominal value should be used; in a MC simulation, some sampling should be done. I'd prefer to hide this case distinction so that a designer instantiating the subcircuit does not need to take care of it. So how can I put "if( MC run )" in Spectre syntax?
Alternative: I could create two subcircuits, my_subckt_nom and my_subckt_mc, with different interiors and let a designer choose which one to instantiate. Hence, my question is not a show-stopper, but such a feature would be nice to have.
Background: The distribution of the subcircuit parameter a is asymmetric. Therefore, its nominal and mean value do not coincide and a case distinction is required in the implementation.
Thank you!
André
    André,
    There's no means of directly detecting you are in monte carlo. However, I can see a couple of possibilities that might be worth trying.
    First, define your statistical variation:
    parameters varyingPart=0
    statistics {
      mismatch {
        vary varyingPart dist=gauss std=0.1
    and then in your subckt do:
    parameters a=varyingPart==0?4:6+varyingPart
    I made the "mean" of the parameter 6 to illustrate this. Note that I didn't do anything to skew the distribution, so you might need to apply some warping function to the varyingPart parameter - and adjust the mean (because the mean of a warped normal distribution won't be 0 any more).
    The above would almost work because there's only a very small chance of varyingPart being exactly 0 in the monte carlo. Even if it is, I doubt it would significantly affect the distribution.
    The other idea is to simply do:
    parameters a=4+(varyingPart>0?varyingPart*2:varyingPart)
    This will warp the distribution (whether it's the warping you want) and consequently the mean won't be 4 any more.
    Note that I've not tried either of these - they are just ideas off the top of my head.
  • anla
    thanks a lot for your proposals. Your first idea exactly performs as required, so I am going with it and have not tried the other.
    For completeness, I add an example netlist:
    ////// resistor test circuit
    //// parameter definitions incl. statistics
    parameters resvar=0
    statistics {
      process {
        vary resvar dist=gauss std=1 percent=no
      mismatch {
    //// subckt definition
    subckt my_res A B
      parameters r1=resvar==0?4:6+resvar
      r1 (A B) resistor r=r1
    ends my_res
    //// circuit definition: force current (I=1A) through resistor
    isource1 (1 0) isource dc=-1 type=dc
    iR1 (1 0) my_res
    //// nominal DC simulation
    dc1 dc
    //// MC DC simulation
    mc1 montecarlo numruns=1e4 seed=1 variations=all sampling=standard \
      donominal=no scalarfile="./mcdata" {
          dc2 dc
    //// print voltage at node 1 - corresponds to resistor value in my_res since I=1A
    print v(1), name=dc1 addto="perf_dc.out"
    print v(1), name=dc2 addto="perf_mc.out"
    As expected, the voltage v(1) in "perf_dc.out" is 4V. From "perf_mc.out", for the voltage v(1), I obtain a mean value of approx. 6V and a standard deviation of approx. sqrt(2)V.
    Kind regards.
    André
