  3. Importing gds to ic5.1 with different view name
  • Views 14411
sesl33
sesl33 over 11 years ago
 Is there a way to import gds from Encounter as a different view name into ic5.1?
The default view is layout, but, I would like to import it as layout_ver0 without overwritting the original layout view.
PS: I know that ic6 can do that, but for this project I need to use ic5.1
Thanks.
    From the IC5141 documentation (Design Data Translators Reference manual):
    Top Cell Name
    The Top Cell Name field takes the name of the cell at the top of the hierarchy that you want to translate, and the name of the view for the cells you translate. If you want to translate all cells in the Stream file to a layout view, leave the field empty. If you want the cells translated to a view other than layout, type the cell name and the view name in the field.
    Default: layout
    For example, if the cell hierarchy is as follows:
    then the some examples of how you can translate cells of how the cells will be translated are as shown below:
    Cells to translate
    Design Framework II view to translate into
    What to type in the Top Cell Name field
    B F
    layout
    B
    C D F E
    layout3
    C layout3
    All cells
    layout
    All cells
    layout3
    * layout3
