  3. How to import a .gds file in Virtuosos with a LAyer-Mapping...
  • Views 4827
How to import a .gds file in Virtuosos with a LAyer-Mapping table/file
RFStuff
RFStuff over 11 years ago
 Dear All,
Our package vendoe sent us a .gds file along with Layer Map File.
 I streamed in the .gds file in CADENCE Virtuoso.
I created a new library named PCB_PACKAGE and attached the PDK (the PDK we are using for chip design) technology file to it.
I also added the vendor's  Layer-MAP file during Stream-in of the .gds file. (User-Defined Data ->Layer Map Table:  Layer-MAP file)
It successfully streamed in the .gds file. When I opened the layout cells ( let's say one cell in the Laibrary ), the layers are not visible in the virtuoso editor.
I deleted PCB_PACKAGE library and again created it and attached the  PDK technology file.
Then I streamed in the .gds file. This time I didn't give the Layer-map file sent by the vendor.
After stream-in, I found the packages but they are shown in PDK layers.
So, how we can see the layers corresponding to Layer-map file ?
Kind Regards,
  • Quek
    Quek over 11 years ago
    Hi RFStuff
    Using the gds layer map file from the vendor is actually correct. I think you should check the strm-in log file for warnings on dropped layers, etc. Perhaps there are mismatches in gds numbers between the layer map file and the gds file.
    Best regards
    Quek
