  3. recording simulation time
  • Views 14992
milind0y
milind0y over 11 years ago
    I want to record the time taken by the simulation run and write it to an file using my Ocean script. How can I find out the time taken by the simulation run?
Milind
  • Tom Volden
    Tom Volden over 11 years ago
    Hi Milind,
    The simulation time will be shown in the output log, so you could parse that, but if you want something within the OCEAN script you could check the time before the run() command and compare it to the time after the command is executed.  Something like:
    timeFile=outfile("./simTime.txt")
    startTime=getCurrentTime()
    run()
    endTime=getCurrentTime()
    fprintf(timeFile "The run() command took %d seconds." compareTime(endTime  startTime))
    close(timeFile)
    TOM
  • milind0y
    Thanks! getCurrentTime and compareTime were the functions I was looking for exactly Milind
