  3. problem in import spice
  • Subscribers 136
  • Views 16398
machha
machha over 11 years ago
I need to generate schematic from cdl through IMPORT --> SPICE .
It is working fine for regular Vt devices but for lvt (low-Vt) devices showing error as
Instance: MM1
Instance has master: 'mos' model/subtype: 'lvtnfet'
Master Cell: 'mos'
Did not find '<reference_lib>.mos:symbol'.
ERROR (SPICEIN-24) Spice in did not find the symbol viewof the master cell "mos"  of the instance MM1.
not sure from where this "mos" master is taking. It is working fine for other devices.
Please help me in debug.
Machha.
  • SavvasSg
    SavvasSg over 5 years ago
    Hi Maccha,
    Could you please share the device.map file you are using to import the lvt devices?
  • Quek
    Quek over 5 years ago
    Hi Machha
    When spiceIn is unable to find a suitable user-defined mapping for a device, it tries searching for generic names such as "mos", "res", etc. You had most likely not included the appropriate reference library or device mapping.
    Best regards
    Quek
