  3. Unified Reliability Multithreading
  • Views 14173
JulianLeander
JulianLeander over 11 years ago
I am using the unified reliability interface for RelXpert.
In the scaleParam() function I want to write the degraded values to a different netlist than the one used for the agingcondition.
The problem is, using multithreading leads to a segmentation fault. I tried using mutexes, but it didn't work, since the mutex could not be initialized in the shared library.
Is there any solution for that?
Best regards,
Julian
