  3. Strange result in SKILL arithmatic operation
  • Views 14246
RFStuff
RFStuff over 11 years ago
Dear All,
In SKILL I did as follows:-
a=1045.0/5.0
 =209.0
int(a)
 =209
But when I did
a=1.045/0.005
 =209.0
int(a)
 =208
Why int() shows different results in the above two cases ?
Kind Regards
    There are quite a few similar posts to this. This is normal floating point rounding errors which you get in any language using IEEE floating point representation. Try using printf("%.15f\n" a) and you'll see the reason. Essentially the binary representation means that base 10 fractions can end up as a recurring sequence (like 1/3 does in base 10).
