  3. How the default lebelling letter type can be made "roman...
  • Views 2435
How the default lebelling letter type can be made "roman" instead of "stick"
RFStuff
RFStuff over 11 years ago
Dear All,
I am using IC5141. In my setting the default labelling (both in case of schematic and layout ) is coming in "stick" letter.
I like to have default "roman"
Could anybody please tell, what modification can achieve this ?
Kind Regards,
  • Tom Volden
    Tom Volden over 11 years ago
    There are several .cdsenv variables that can be set.  Try the following:
    layout  labelFontStyle cyclic  "roman"
    schematic  createLabelFontStyle  cyclic  "roman"
    schematic  instLabelFontStyle  cyclic  "roman"
    schematic  noteFontStyle  cyclic  "roman"
    schematic pinLabelFontStyle  cyclic  "roman"
    schematic symbolLabelFontStyle  cyclic  "roman"
    TOM
  • RFStuff
    Dear Tom,
    Thanks for your reply.
    Looks like * schematic pinLabelFontStyle  cyclic  "roman"  * is NOT working.
    I am still getting stick for PIN label But in all other cases it is working fine.
    Could you please tell why it is so ?
    Kind Regards,
  • Tom Volden
    I'm away from my computer right now so I can't try it myself, but a quick check of the documentation suggests that you need to enable the ability to set the pin label font style before setting it.  Try to following:
    schematic  pinLabelSetFontStyle  boolean  t
    Odd that this is the only one that seems to need to be enabled before setting it, but that's what it looks like to me.
    TOM
  • RFStuff
    Thanks . It indeed worked.
