  3. stb analysis / phase margin & gain margin functions
  • Views 20725
david0526
david0526 over 11 years ago
hello,
i have a question on stb analysis in spectre.  i can successfully perform the analysis, and can plot loop gain's phase/magnitude without issues.  however, when i try to select other functions, like PM Frequency, GM Frequency, Gain Margin or Phase Margin, i get a notice that the particular
"... metric is not found.  Perhaps the stb frequency sweep range was no adequate".
i tried many different sweep setting, but can't get this function to work.  is there something obvious i'm missing?
thanks in advance.
    ShawnLogan over 11 years ago +1
    Hi David, > I tried many different sweep setting, but can't get this function to work. is there something obvious i'm missing? Perhaps you have already verified this or it is obvious, but are you sure…
  • Frank Wiedmann
    Frank Wiedmann over 11 years ago +1
    Phase margin does not exist if the loop gain magnitude does not go below 0 dB, gain margin does not exist if the loop gain phase does not go below 0 degrees (due to the slightly unusual definition of loop…
  • david0526
    david0526 over 11 years ago +1
    Shawn, Frank, Thank you both for the comments! Yes, you were absolutely right... my sim had loop gain > 0dB throughout. Once I added some compensation and loop gain crossed 0dB, all the metrics appeared…
    Hi David,
    Perhaps you have already verified this or it is obvious, but are you sure that the system you are simulating shows a phase shift of - 180 degrees? For example, if the open loop phase does not cross -180 degrees, then the phase margin is not defined. This suggests that the phase margin frequency and gain margin frequency are also not defined.
    You might try plotting the open loop gain and open loop phase from your analysis and visually inspect the two to verify the existence of a phase shift of -180 degrees and the gain margin (if it exists).
    I hope this helps David,
    Shawn
  • Frank Wiedmann
    Phase margin does not exist if the loop gain magnitude does not go below 0 dB, gain margin does not exist if the loop gain phase does not go below 0 degrees (due to the slightly unusual definition of loop gain phase in the stb analysis, see http://www.designers-guide.org/Forum/YaBB.pl?num=1124688329).
  • david0526
    Shawn, Frank,
    Thank you both for the comments!  Yes, you were absolutely right... my sim had loop gain > 0dB throughout.   Once I added some compensation and loop gain crossed 0dB, all the metrics appeared as expected!
    Again, thank you for the help.
    David
    P.S. Frank, thank you also for the "further reading" link.
  • FormerMember
    FormerMember over 11 years ago
    Great!
  • Frank Wiedmann
    If you would like to have some further "further reading" on loop gain simulation, you can take a look at my webpage https://sites.google.com/site/frankwiedmann/loopgain.
  • david0526
    Many thanks for further "further reading", Frank! Heading there now...
