  3. virtuoso display problem
  • Views 15349
reddevil011
reddevil011 over 11 years ago
Hello. I've come across a display problem. I am using spectre to simulate a schematic. After the transient simulation is done, I use "direct plot" to plot some signals in the schematic. However, The colors of the the ploted-signal in waveform and the corresponding signal high-lighted in schematic are different . How can I correct this problem? Thanks~~
F.Y.I. My cadence version is IC 6.1.4
    I don't recall (IC614 was a while ago now) whether there was a problem that was fixed during the life of IC614 and maybe is solved by using the latest hotfix. That said, IC614 is no longer available for download - I would strongly suggest moving to a later supported version where I don't believe this happens, and if it does, you should contact customer support so that we can figure out why it does in  your environment. I'm not aware of any user setting which would make this break.
