  3. check wire connections by color
  • Views 18952
Clidre
Clidre over 11 years ago
I have a big schematic with sub-blocks and connections by labels and I would like to check the connections. I remember some years ago I used a feature in the schematic editor where every net is highlighted with a different color. In this way, it is easy to check the connections. I can't find how to do that again. The only thing that I have found is View->Net Highlighting, but it only highlights the net I put the mouse on, with no colors. Does anyone knows the feature I am referring to and how to activate it?
    Use the Create->Probe menu (e.g. add net). This is often on the "9" bindkey. You can also do it by the right mouse button menu in the navigator.
