  3. Area measurement in Virtuoso
  • Subscribers 133
  • Views 17182
archive over 19 years ago
Hi all,
Is there a way to get the area of a non rectangular selected shape on a given layer in Virtuoso ?
Thanks in advance !
Best regards
Herve
Originally posted in cdnusers.org by hm001
    Herve,
    Look at sourcelink solutions 11091704, 11248454 and 11328674 .
    Originally posted in cdnusers.org by adbeckett
    Here is the basic formula from: http://www.geometryalgorithms.com/Archive/algorithm_0101/algorithm_0101.htm#area2D_polygon() // area2D_Polygon(): computes the area of a 2D polygon // Input: int n = the number of vertices in the polygon // Point* V = an array of n+2 vertices // with V[n]=V[0] and V[n+1]=V[1] // Return: the (float) area of the polygon float area2D_Polygon( int n, Point* V ) { float area = 0; int i, j, k; // indices for (i=1, j=2, k=0; i<=n; i++, j++, k++) { area += V[i].x * (V[j].y - V[k].y); } return area / 2.0; } Here is some simple skill: procedure(getObjectArea(obj) let(((area 0.0) sum lastPt firstPt crdList dx dy) case(obj~>shape ("polygon" sum = 0 crdList = obj~>path firstPt = lastPt = car(crdList) foreach(crd cdr(crdList) sum = sum + ((xCoord(crd) - xCoord(lastPt)) * (yCoord(crd) + yCoord(lastPt))) lastPt = crd ) sum = sum + ((xCoord(firstPt) - xCoord(lastPt)) * (yCoord(firstPt) + yCoord(lastPt))) area = area + (0.5 * abs(sum)) ) ("rectangle" dx = xCoord(car(obj~>bBox)) - xCoord(cadr(obj~>bBox)) dy = yCoord(car(obj~>bBox)) - yCoord(cadr(obj~>bBox)) area = area + abs( dx * dy ) ) ) float(area) ) )
    Originally posted in cdnusers.org by dmay
    Try Again:
    procedure(MSutGetObjectArea(obj)
    	case(obj~>shape
    	    ("polygon"
    		sum = 0
    		crdList = obj~>path
    		    lastPt = crd
    	    ("rectangle"
    	float(area)
    	case(obj~>shape
    	    ("polygon"
    		sum = 0
    		crdList = obj~>path
    		    lastPt = crd
    	    ("rectangle"
    	float(area)
    <\pre>
